Magsy
- Nov 9, 2004
I'm possibly in, depends on the style. I don't much like the one depicted on the site, maybe in black with less holes cut in it...
Originally Posted by BrokenEnglish europeans might consider those marvelous galaxy cases of audiokit.it... at least... i would do so.. |
Originally Posted by amb OK, while we're on the subject of enclosures, and since the boards are expected within days now, I think it's fine time to check for interest in a Par Metal 20-series custom-sized case group buy. As I mentioned in a previous post, Par Metal can make any custom size you want, but it's pricey in single quantities. I asked them about a 6" wide x 2" high x 8" deep case, and the quote was something like $70. However, that price drops to the mid-$30 range for a quantity of ten or more, which is quite reasonable. If there is enough interest, and people could agree to a common specification (size, color, finish, etc), then I suggest someone should step up and coordinate this. I am too busy to conduct this myself, so I am asking for a volunteer. Maybe a separate thread for this is appropriate? |
Originally Posted by uzziah so the par-metal idea would be that we would decide on a CUSTOM size case for the m3 and then groupbuy that custom size. yes? |
Originally Posted by amb Yes. The idea is to make the price of the custom sized cases reasonable with the group buy. Since only ten is enough to get the price down, I guess it's possible to have a couple of (size/color/finish) combinations if we could get enough quantity together for each one. By the way, the 2" high case has an available internal height of 1.85" after subtracting the thickness of the top and bottom panels. It will fit a board with the 1.5" heat sinks, but just barely. See diagram: You'd have to use short (0.125") spacers to mount the board and put an insulating plastic sheet below the board to safeguard the heat sink screws and parts pins from touching the bottom, and that gives only 0.145" clearance above the heatsink to the top cover. Also, the volume/bassboost pots will have their centers below the centerline of the front panel by 0.205". There isn't enough pin length on the Alps blue velvet to raise them to the center. But then my home-built case also has the pots below the centerline and it looks fine... |
Originally Posted by morsel Or you could use 1" heat sinks, which is OK as long as you don't jack up the bias too high. |
the heatsink being closer to the lid would actually be a good thing. conduct the heat more directly from the hs to the case and thus radiating to outside air. |
Originally Posted by silvervarg The major concern is if heatsinks touch the case (e.g. when case is pressed down). Unless you use insulation the heatsinks are live, so if they touch the case we can have a major shortcircuit. In general you want to have air slots so air can escape through the chassi, preferable just above the heatsinks. The distance from heatsink to top of case is not very important. |
