Ok,
many thanks AMB for this so complete answer. I will use that, for sure.
For the input DC offset, I measured my iPod, the headphone output is somewhere around 0.1mV, and the line output is around 0.3mV. These do not move when on internal battery, and fluctuate from 0.2 to 0.4 for the line output when on wall charger. If this is passed through a voltage gain of 5, to a Grado, the headphone will have 1 to max 2 mV through 32ohms, meaning 0.03125 to max 0.0625 mA. Is this a real threat, for the headphone is expensive enough at least to burn them!
Ok, now if this is too much, I should put a cap inline with the input, now, before or after the Linkwitz pcb? And what kind, and what value? will it interact with the crossfeed or not (surely, but how to minimize this effect)?
One of my Cmoy (front buffered) have a Linkwitz high-Z implementation, and a gain of 4 to 5, I'm satified with the volume level, can I just assume I will have the same volume level if I stick to a gain of 5 in the M³?
How can I further fin-tune the M³ for Grado / OPA627, Gain 5, besides 27pF in place of 33pF, are there specific bias settings?
I want to achieve gain 5 without touching to the R4 (10kOhms), so I need r3 = 2500 Ohms, right? Is it the optimum, regarding current and noise, for 4kOhms and 1kohms work also, and a lot more combinations.
Many many thanks again, I want to study it and be sure I understand everything and be convinced I can cope with all the aspects before beginning this.
All the best,
Greg
