Anyone realized you could attempt a deeper insertion into your ears with stacking of rubber washers on the filters or buying thicker version of it like watch gaskets.
I will try that when I'm free
Back to normal!Did it stop working forever or did it go back to playing normally?
What cable pray tell?These keep impressing me more and more. The soundstage though, it's very wide for an iem. It does nit compete with my open backs but what makes the A7 so damn special is that black background and depth. These have such an open feeling to them and air which makes them feel and sound open. The instrument placement and accuracy is TOP Tier. I have settled on the silver filters. I feel that the cable I am using tames the highs just slightly while giving more extension in the treble and keeping that amazing detail. It also helps add some sub bass while keeping it extremely clean and precise. With the stock cable I feel silver filter can sometimes but just a touch on the brighter side but still very goood.
Not that I have heard.Are there any iems that compete with lz a7 at this price bracket?
The blessing 2? That's it?
Tri I3, although is much cheaper?
I3 is very different sounding from the A7 but technically a tier to a tier and a half behind I feel. Blessing 2 screams at you, A7 doesn't but can if you want it to, the versatility of the A7 is really a strong suit and overall quality wise I feel it doesn't lose out at all to the b2Are there any iems that compete with lz a7 at this price bracket?
yeah, take the strongest factor of the B2, the technicalities. The A7 is still on another level. (and I am using the config with the most treble reduction....so suffice to say the rest of the configs are beating the crap out of the B2 on the technicalities).I3 is very different sounding from the A7 but technically a tier to a tier and a half behind I feel. Blessing 2 screams at you, A7 doesn't but can if you want it to, the versatility of the A7 is really a strong suit and overall quality wise I feel it doesn't lose out at all to the b2
Not any better, just different. A7 is one of the most versatile IEMs, where almost everyone should thoroughly enjoy it.[QUOTE = "MikonJuice, post: 15983764, membro: 192400"]
Ci sono iem che competono con lz a7 a questa fascia di prezzo?
La benedizione 2? Questo è tutto?
Tri I3, anche se è molto più economico?
[/CITAZIONE]
NM2+ ?
Or maybe Tanchjim Oxygen ?
Its the CEMA Electro Acousti CS Series UP-OCC Copper litz 8 core cable.What cable pray tell?
I'm curious because I ordered TRI I3 and it has to arrive. Is there anything where TRI I3 wins over LZ A7 or loses across the board in comparison?I3 is very different sounding from the A7 but technically a tier to a tier and a half behind I feel.
I really need to un-watch this thread.yeah, take the strongest factor of the B2, the technicalities. The A7 is still on another level. (and I am using the config with the most treble reduction....so suffice to say the rest of the configs are beating the crap out of the B2 on the technicalities).
And the A7 sounds much more natural than the B2.
Yup there are, staging wise the I3 just sounds massive, the A7 layers better and images more precisely but in terms of raw size the I3 is better. I3 also conveys sense of scale better, so it sounds properly big. In terms of tone the I3 has those lovely planar mids that are really lush and immersive, whereas the A7 is more like a musical sounding monitor. If I owned both at the same time there would definitely be days where I'd reach for the I3 over the A7. So really it's not like the I3 is a lost cause, I loved mine and I still think it's excellent in its price bracket, it's just that the A7 is more versatile and also more refined around the edges, like in terms of detailing, fine texturing, bass control and overall micro and macro dynamics the A7 just performs that bit better than the I3, which is to be expected given the cost difference...
