Lyr 3 - The new Coherence™ and Continuity™ hybrid amplifier from Schiit - Impression & discussion thread
Apr 12, 2018 at 9:44 PM Post #436 of 3,386
Different rooms and different uses! In my library/listening room, I have my turntable and I sit close to both the Lyr and the 'table, so I can use either headphones or speakers. That was actually a big reason for getting it, because it fits what I wanted to do pretty perfectly: have a preamp with line in (for my DAC), phono stage, and headamp!
The setup in my living room is different, there I never use the headphone amp in the integrated amp I currently have, and neither do I use most of its other features (or power), so I'm replacing it with a Saga and a little Parasound power amp.
That makes total sense, thanks!
Apr 13, 2018 at 9:12 AM Post #438 of 3,386
Apr 13, 2018 at 12:28 PM Post #440 of 3,386
weird disconnect between the timbre of the upper mids/treble and the lower mids/bass.
Thoughts?
I am not the best person to offer feedback on this, as I am fairly new to desktop gear and this is my first discrete amp and I don't have other amps to compare Lyr 3 with. But let me just add my 2 cents.
Switching the Gain to HG makes the upper-mids brighter and adds a bit of hardness in the treble, which might be partially responsible. Or are you observing that in LG itself? The DAC could have an influence too. I am using a Hugo 2 which is slightly mid-centric, i.e. it has very good presence in the center mids that bridge the lower-mids and upper-mids. Because of which I don't feel the disjoint. Let me try using my Lotoo Paw Gold as source and get back to you.
Source: Hugo 2
Tube: Tung-Sol 6SN7, Module: No Module
HPs: HD800S, Audeze LCD-i4
Apr 13, 2018 at 3:58 PM Post #441 of 3,386
Thoughts?
You're not the first to hear that in the Lyr 3.
Apr 13, 2018 at 9:19 PM Post #443 of 3,386
Well, a sad tale, I installed a NOS Sylvania “Bad Boy” and I was greated by a puff of white smoke! I immediately unplugged the Amp, pulled the offending tube out, and let it cool off for a bit.
Then out of curiosity, I installed a tube I know and it’s playing like nothing happened, has anyone experienced anything like this?
Apr 13, 2018 at 10:14 PM Post #444 of 3,386
A puff of white smoke from the amp? Or the tube? I've never seen a tube go up in smoke, although I've seen a couple go nuclear.
Apr 13, 2018 at 10:20 PM Post #445 of 3,386
Nuclear? Like what did you see? I've heard tubes can implode
Apr 13, 2018 at 10:31 PM Post #446 of 3,386
It was out of the amp, I couldn’t find any breaks in the tubes glass. Though I wonder a break in the base could be the issue.
Apr 13, 2018 at 10:48 PM Post #447 of 3,386
I'd be on the emergency phone line with Schiit.
"MY BABY! OMG, MY BABY IS ON FIRE!!!! OMG SOMEONE HELP OMG!!!" <insert hysterical crying>
Apr 13, 2018 at 11:51 PM Post #450 of 3,386
How did you know, did the Schiit Line Operator tattle on me ;-)!
