Low bit-rate
Jan 2, 2008 at 3:08 PM Thread Starter Post #1 of 27
spickerish
Hi
I'm thinking of buying the Ety ER4P but 80% of my music is ripped at 128 kbs. Will they be too unforgiving or will I still be able to enjoy my music. Are the Shure se210's more foregiving or are they about the same?
Jan 2, 2008 at 3:20 PM Post #3 of 27
Thanks, but what do you mean with flaws? What will it sound like?
Jan 2, 2008 at 3:35 PM Post #4 of 27
The main thing I notice with files encoded with a low bitrate is that the cymbals (and treble in general) sound "watery", for lack of a more intelligent word.
Some people that I know don't really notice it, but I can always pick it out and it is very annoying to me. I think that anyone can hear the difference if they are made aware of it, but some people just don't notice it.
Jan 2, 2008 at 3:49 PM Post #6 of 27
Originally Posted by ILikeMusic /img/forum/go_quote.gif
128 kbps can sound pretty decent with some encoders and not-so-great with others.
x2 on that.
Now that I think about it, a lot of the files that had the problems that I complained about in my earlier post were converted awhile ago. The more recent of the few files that I have that are 128 kbps sound decent. Of course, the lossless files and even the 192 kbps files sound better, but if you use a good encoder (like LAME?) it will sound alright.
Jan 2, 2008 at 3:51 PM Post #7 of 27
I'm sorry but I don't know what an encoder is. I'm a newbie to all this audiophile stuff. I just use iTunes if that helps.
Jan 2, 2008 at 3:57 PM Post #8 of 27
well-encoded 128 can sound alright, but like anything in audio the little audible flaws will drive you nuts once you start to hear them. I'd start a slow systematic bitrate improvement if I were you, and make do with your old files in the meantime. Also, what dac/soundcard/dap are you using? It doesn't mean much to talk about these differences without that piece of information, because it can make such a big difference.
Jan 2, 2008 at 3:58 PM Post #9 of 27
The majority of my ~5500 songs are encoded at 192 kbps AAC VBR and they sound great to me. I'm sure that someone with more expensive equipment and/or more detailed listening might say that it sounds horrible.
For albums that are very important to me or more complex, I use lossless encoding, and truthfully, it does make a difference in the sound.
You can switch your importing/encoding settings by going to iTunes and (on Windows) going to Edit>Preferences>Advanced and clicking on the "Importing" tab. You can switch your preferences there.
I would suggest encoding with AAC if you are pressed for space, because from what I've heard, it offers higher quality in a smaller file than mp3. However, if you want files that are compatible with the most devices/programs, you would have to go with mp3.
Jan 2, 2008 at 4:05 PM Post #10 of 27
Thanks for the advice. But is there a program where I can turn 128kbs into higher bits since I don't have all my old cd's anymore.
Jan 2, 2008 at 4:08 PM Post #11 of 27
Unfortunately, that's impossible. Once the data is compressed [and all the bits are thrown out], it's gone for good.
Jan 2, 2008 at 4:09 PM Post #12 of 27
You can't turn low bit-rate music into higher bit-rate music.
Jan 2, 2008 at 4:13 PM Post #13 of 27
As everyone else has said, it's impossible.
While you can technically use a converter and convert a 128 kbps file into a 192 kbps file, it will sound worse than the original 128 kbps file did. You're basically taking an already highly compressed file and compressing it again.
Jan 2, 2008 at 4:18 PM Post #14 of 27
As you can read, the mp3 is a lossy bitrate. That means some informations are lost when you use an encoder. A bitrate of 128 kbps is lower than 192 kbps or 320 kbps. It equals you lose more information in a low bitrate than in a high bitrate. Because of that, a high bitrate takes more place than a low bitrate on your hard-disk.
So, don't re-encode your 128 kbps mp3 in higher bitrate. The sound quality will be less you in the higher bitrate than in the 128 kbps.
No chance: the only possibility is to take the cd's and encode them ONCE in a higher bitrate.
Ah, someone was faster than me...
Jan 2, 2008 at 4:24 PM Post #15 of 27
Okay thanks again. But now for my main question. I want to buy a new pair of earphones and which of these 2 would you recommend to me: Ety ER4p or the Shure se210, I live in Holland and I can only get the ety's for 185 euros, the shure's however are only 150 euros. Do the ety's really sound that much better with the low bit-rate in mind or am I better off with the Shure's and a bit of money left over.
