I was talking about the old Android smartphone with just a 3500 mAh battery while the more recent phones come with up to 6000 mAh.30% in 1 hour seems a bit much to me, but I have not kept time with my S2.
I don't know if low gain saves battery, but I'd give it a try. Also because of sound quality A firmware update might be of help, although I have not checked the relase notes.
Mind that I have this beep issue with 96kHz streaming from Quobuz. This is reproducible with my S2 (with UAPP on Android and Roon on Windows) but I have not heard of others having this issue. I think it came with 2.0.0.4 update, but it might have been there before and I just did not listen to any 96 kHz Quobuz content in the short time I had the older firmware installed.
Since I think of upgrading it in 2022, hopefully the battery drain won't be the issue no more.
Do you think the gain level is affecting the sound quality?
I haven't noticed much difference, but I definitely need more time with the S2.
I haven't mentioned the firmware... I have initially checked the S2 right out from the box, but then I upgraded it to the latest version the same evening and tested again.
I think those removed EQ presets won't be missed much.
Still the Line-Out is a fair trade-off.
I haven't tried Quobuz yet.
TIDAL is my primary source of music.
Therefore I can't comment on your issue.
Everything is working fine for me.
The only issue I also had was the short hiccup of sound in the beginning of each MQA track.
It can be noticed both in TIDAL app and in UAPP.
But it's a minor flaw that can be neglected.
