jsmiller58
I understand it the same as you do... Max out your source - it is a digital output so you won’t introduce any distortion. Then tune the volume on the S1. You want to run your final amp stage (S1) at the lowest comfortable volume to avoid distortion - the higher the volume of your source the less the amp,needs to be pushed to its limit where it will possibly begin to distort.I just picked up a paw s1 to use on quick go with my IEMs when I don't want to carry my DAP and when I was to use iems with videos. I've read back a few pages but haven't found an answer to my question so I'm going to post here. My apologies if it's been answered before.
Does everyone just set their source to max volume and then control volume on the s1? For example, max volume on phone, paw s1 volume control from there (low volume settings in this setup)
From memory of the audio world usually you set a source to max and control volume on the amp so I'm wondering if this is the recommended setup with the s1 or if I should set my phone to maybe half volume and the s1 to where I want the sound at. Or in Reverse, s1 near max, phone to control volume.
Any insights are appreciated!
I am able to independently adjust volume on both my Android phone and my S1. I think I can also do the same on my iPad. I don’t have an iPhone to test.
