Sulbh
- Jan 12, 2014
Have you compared them personally?Definitely, more power and better sound and added features.
Very subtle difference between s1 & s2 in SQ. It is better to stick to S1Definitely, more power and better sound and added features.
Did you compare them personally?Very subtle difference between s1 & s2 in SQ. It is better to stick to S1
Yes. I have two models S1 & S2. The only difference is extra feature of easier LO option in S2 while LO in S1 is farmware based & little bit cumbersome but still easy to enter. Go for S1. Soundwise almost same. Can't differentiate.Did you compare them personally?
Hi Is Paw S2 worth upgrading if you have Paw S1?
Do you have any other dongle DACs you can compare it with?Yes. I have two models S1 & S2. The only difference is extra feature of easier LO option in S2 while LO in S1 is farmware based & little bit cumbersome but still easy to enter. Go for S1. Soundwise almost same. Can't differentiate.
L&P w2 dac. Better than S1&S2. Of course much pricey. But S1 value for money which is 90% of SQ of L&P w2. Don't confuse regarding SQ. As we grow ability to discern HF diminishes too. As per my understanding too much fuss about SQ make someone confused & ultimately makes mistakes. Hope i am able to clarify you. Good day.Do you have any other dongle DACs you can compare it with?
Do you have any other dongle DACs you can compare it to?I have them side by side too.
I'd say it is a worthwhile investment, better sonics, better driving power. The main tuning or sonic signature is similar, but if you have revealing / detailed headphones / IEMs, you would probably want to go with S2. S1 is still a good dongle DAC AMP.
It's the same with every deviceHi can anyone confirm if we can use 4.4mm balanced to 3.5 mm adapter with the S1? I think we cannot use balanced to unblanced adapters on sony players. Is it same with the S1?
So only way is to buy balanced cables?It's the same with every device
I guess the question is why? The S1 has both 4.4mm and 3.5mm ports. Plugging a 4.4mm into a 3.5mm adapter to use with a S1 seems superfluous...Hi can anyone confirm if we can use 4.4mm balanced to 3.5 mm adapter with the S1? I think we cannot use balanced to unblanced adapters on sony players. Is it same with the S1?
Conventionally, use the 3.5mm ports for SE and 4.4mm for bal.I guess the question is why? The S1 has both 4.4mm and 3.5mm ports. Plugging a 4.4mm into a 3.5mm adapter to use with a S1 seems superfluous...
Yes. That's the catch. Thanks for info.Conventionally, use the 3.5mm ports for SE and 4.4mm for bal.
- You can connect balanced headphones (2.5mm/4.4mm) to unbalanced ports (3.5mm) because it ties the ground terminal together and nothing bad happens
- But if you connect unbalanced (3.5mm) to balanced ports (2.5mm/4.4mm) through the 3.5mm , it can potentially damage the amp because you are shorting the left amp and right circuits
Not all headphones support balanced cables?Conventionally, use the 3.5mm ports for SE and 4.4mm for bal.
