sillysally
- Aug 3, 2008
I am catching this discussion a bit late but basically I have similar feeling to you regarding the realizer: I am not sure I want to include imperfections from the listening environment. However, in my case, the purpose would be to listen to surround sound from movies. As I understand it, these mixes are made assuming that the surround speakers are in a typical listening environment with some reflections, isn't it? Just like it is advised to not have the surround speakers radiate directly to the receiver but use a bit of bouncing around the back and side walls to improve the realism. Even for traditional 2-channel mixes, they actually don't sound great from dead sounding room (I have tried before in full anechoic chamber).
So, in conclusion, I believe that the best option here, as has been recommended is getting PRIR from a high quality setup...
On another topic, I haven't read yet through the thread but any info on a possible revised unit accepting digital inputs / included typical decoders? It's a bit compromising to feed the unit with analog because this must get converted back to digital for the processing and then back to analog... Also, I am not sure head tracking is absolutely necessary when primary usage is movie watching...?
arnaud
What ever the room and audio system you are making your PRIR from should sound the same when wearing your headphones.
Note, the better the headphone system the better the reproduction of the PRIR will be.
Ask Lorr digital inputs. The Realiser uses a PCM 1794 DAC (or 1796 i think).
No the head tracker is not necessary to use.
