Tomus4
- Sep 19, 2016
Hi b0bb,
Did you checked Burson v5 in the I/V circut?
Hi b0bb,
Ah - maybe I mis-remembered. I thought b0bb said the v5i's weren't suitable.
FWIW, I've got v4 Bursons in the output stage of the LKS - they also sound good.
I'd like to put the lid on the LKS temporarily in order to keep animals away from my handiwork (and the 240v AC, which I doubt is good for their fur). However, I am a little concerned that the jump lead providing the regulated voltage to the Vin pin may work loose.
If it does come free, then I assume the DAC will let me know by going silent as soon as it detects no input on PIN 24. Is this correct?
Thank you very much for response b0bb.
What do you thing about Burson v4 ? Did you checked it in RCA and I/V section?
The jump lead carrying power should be secured, it can do a lot of damage if the lead touches anything else on the motherboard.
Out of curiosity, can the ES9018 operate without a master clock?
Out of curiosity, has anyone compared this to something like the gustard x20u?
I have a x20u, but am considering this unit.
