Little Dot Tube Amps: Vacuum Tube Rolling Guide
Apr 19, 2018 at 7:40 AM Post #11,508 of 13,434
I rolled many tubes on my LD Mk4 and I have the 6ZH1P-EV and the 6HM5.
IMHO, the 6HM5 is a much better all-arounder, that is, before you tried the C3g, which is much pricier and needs adapters!
Luckily, the 6HM5's are surprisingly inexpensive and are plug-in compatible to EF95, which is the greatest news to us!
Apr 22, 2018 at 5:11 AM Post #11,510 of 13,434
So guys, quick Mk 2 suggestion.
Going for voskhods 6zh1p and also sylvania GB5654. Might pick up some 6hm5 along the way and are GE JAN 5654 worth it?
Power tube recommendations? Seems like 6N6P-IR are well sought after here and cheap. Can those 6H30P work with MK2 without an adapter or changing jumper settings?
Much appreciated guys and happy rolling! :)
Apr 22, 2018 at 5:46 AM Post #11,511 of 13,434
Personally. I've found the GE "5 Star" a slightly better choice than the JAN5654. Seem a bit more detailed. Maybe just my ears though. Definitely try the 6HM5s but make sure you get the taller version. Good luck.
Apr 22, 2018 at 6:43 AM Post #11,512 of 13,434
Thanks man. Suggestions for power tubes? Tbh i'd like to play safe and go for the swap and play types without messing around too much with the circuitry.
Apr 22, 2018 at 7:07 AM Post #11,513 of 13,434
Are the GE 5 star carry the same sound sig as the JAN5654 though? I do like the JAN because its tubey neutral sound play really well with Rock music. An improvement over that very sound will be very welcome
Apr 22, 2018 at 11:45 AM Post #11,515 of 13,434
As I say, the 5 Star seemed a bit more detailed to me than the JAN5654. Not much between them TBH though, and both really good for rock. Both seem to go well with female vocals as well, (Joni Mitchell's Hejira album sounds amazing with them.)
Apr 22, 2018 at 2:04 PM Post #11,516 of 13,434
JAN 5654W are a better choice than 5Star tubes for me. Incredible ratio quality/price has Tesla 6F32 and Voshgod 6zh1p-ev. I've tested Voshgod date 1985. Russian power tubes are very affordable.
Apr 28, 2018 at 6:58 AM Post #11,518 of 13,434
I assume that Telefunken is a better choice. This brand is one of the most famous tube producers and you can't do a mistake with them :wink:.
Apr 28, 2018 at 7:52 PM Post #11,519 of 13,434
I decided to get a Little dot Mk.II, and I got Novosibirsk 6N6Ps and British Mullard M8100s.
Compared to my solid state amp (Sabaj D3), the tubes have made my DT990s a lot less bitey in the highs (though admittedly I do sometimes enjoy the bitieness) and a lot warmer in the mids and lows.
As a side note I'm still using the DAC in the Sabaj D3, and I've ordered a pair of Voshkod 6J1P-EVs and GE5654Ws to try out.
