Little Dot Tube Amps: Vacuum Tube Rolling Guide
- Thread starter Dept_of_Alchemy
mattrudy80
2nd marking says E42.Other markings I found: Thanks gibosi!
gibosi
- Oct 18, 2012
E42 doesn't seem to correspond to a Mullard production code....
So I have no idea what factory manufactured these tubes....
Could be BEL, India. They seem to have made the type and sometimes used nonstandard codes.
mattrudy80
Thanks. I'll see if I can find any that are similar. The closest I have found so far that physically look similar with the tab bent up towards the getter are Sylvanias.Could be BEL, India. They seem to have made the type and sometimes used nonstandard codes.
mordy
- Aug 8, 2010
Hi m80,Thanks. I'll see if I can find any that are similar. The closest I have found so far that physically look similar with the tab bent up towards the getter are Sylvanias.
Try Google images - type in the tube designation and scroll through the pictures; you may find what you are looking for.
I had a different Channel Master tube that said Japan, and I finally found a NEC tube that was identical so I found out who made it.
BELs on ebay:Thanks. I'll see if I can find any that are similar. The closest I have found so far that physically look similar with the tab bent up towards the getter are Sylvanias.
mattrudy80
mattrudy80
Amazing how Tung Sol JAN-6AJ5 from '44 sound so much better than Tung Sol JTL-6AJ5 form '56.New set in today! Can't wait to give em a try.
mattrudy80
Anyone have any experience with National Union 6AG5's? I found an old pair that look new at a surplus store and didn't expect much, wasn't even sure if they worked. Thus far in my tube rolling journey these are by far the most relaxed sounding, great for male vocals such as Ray lamontagne and seem to be a good all arounder.
mattrudy80
sghound
- Jan 20, 2007
does anybody know what the difference is between v2 and v3 of the mk2 circuit board?
Quick question - has anyone used the 6SN7 (or similar) tubes in place of the 6H30P in the MkVIII / Mk8 and, if so, which adapters did you use?
Scutey
bjj51
- Dec 23, 2015
Would the ld3 work with sensitive headphones like the fostex x-00 or would I have to get an ss amp?
