Policar
- Aug 27, 2011
Policar,
I had those as stock tubes with my MK III, i'm fairly sure they are French RTC tubes NOT Mullard, they are ok but not as good as Mullard, if you want Mullard the ones to go for are the mill spec versions, the M8100 (EF95), or the M8161 (EF92), and as for the power tubes Octavian is right, the 6N6P and 6N6P-IR are a definite improvement over the stock, as to which is better as always it's very subjective, the 6N6P is slightly warmer with stronger bass, the 6N6P-IR is cooler slightly better clarity/detail and a tad less bass. Here is a link to some Mullard M8100 to give you an idea.
http://www.ebay.co.uk/itm/M8100-CV4010-EF95-MULLARD-BLACK-PLATE-8140-NOS-E-MATCHED-PAIR-VALVE-TUBE-A16-/371599617046?
hash=item5685102c16:gy4AAOSw7KJXDpk
Thanks, I'll return these and get some of those. Where should I buy them or should I just trawl eBay? Now I want to go somewhere reliable.
Will it make a big difference? Right now the amp sounds awful compared with the crack, which has good tubes. The 6N6P sounds prefect for me, I need more bass.
