mimart7
- Dec 26, 2014
Yes, Swap Socket A, with Socket B. Just grab the tubes by the sides, and you can just wiggle them out out. Don't be too rough.
I just opened the Bottom Chassis just now. How do I swap Socket A with Socket B?
It looks like it is soldered to the circuit board...
Power down the amp, wait 10 minutes, swap the sockets the the tubes are in.
By swapping the sockets, do you mean I should move Tube A from the left side to the right side and vice-versa?
Or do you mean I should open the amp's bottom chassis and swap the white sockets?
By the way, is there a specific way to handle the tubes? Like I shouldn't touch them by hand or something?
So far I use tissue to take them on and off to minimize fingerpirnts. But if there is a proper way of handling tubes... I will do it.
He means swap the tube what i use to swap tubes is a rubber finger that i fit over the tube doesnt slip when removing .about those rectangular pieces you talked about those are called jumpers and should be in your amp depending on the family of tube you are using check the thread for pictures or your manual because for example for EF 95 family of tuibes the jumpers should be on certain pins and for EF92 tubes on other pins this is imporant just research JUMPERS atop the page where its writen SEARCH THIS THREAD
I read the manuals yeah, I didn't know that the small rectangular thing was the jumper though, before I opened the bottom chassis. Those jumpers of yours looks nice, maybe I'll find one off e-bay. When i opened the bottom chassis, my amp was open circuit on the gain setting, so i put 2 jumpers to close them to make the gain back to 3.5 Low Gain. And uh, I re-check the tube jumpers setting, moved it to make them 6J1.
On that note, one of the jumper of mine gone bad though, the silver metal and the black plastic got separated from each other when I tried to remove them from the 408A side to the 6J1 side. But it's one of 6 and with 6J1 there are 2 unused jumpers so I'm covered. But that extended jumpers on your picture looks pretty convenient too.
On the DeoxIT, there is only 1 store in the whole nation that is selling them and I'm not sure about shelling $55. So that's my update. Have also swap the tubes between A and B. I haven't try them again though because I only have one PC power cable. So I'll try them again when my PC are off.
He means swap the tube what i use to swap tubes is a rubber finger that i fit over the tube doesnt slip when removing .about those rectangular pieces you talked about those are called jumpers and should be in your amp depending on the family of tube you are using check the thread for pictures or your manual because for example for EF 95 family of tuibes the jumpers should be on certain pins and for EF92 tubes on other pins this is imporant just research JUMPERS atop the page where its writen SEARCH THIS THREAD . pictures below are the longer version of jumpers that i use in the LDMK3 because i dont have to remove cover but the short jumpers in mk3 are a pain to remove .About cleaning pins personnally i refuse to pay $20.00 and more for deoxit i buy another brand thats around $7.00 a can but first i use sandpaper to clean pins then the cleaner
I hope i can find one locally. On top of not needing 100 pcs of jumpers, regardless of price, anything that enters the country over 10 in quantity will be tagged as "Indication for Retail or Distribution", and it's just a mess to take care of, for individual entity.
I really don't know where I can find htem though, tried Ace Hardware and the PC District in my city, and they don't have both Power Cable nor Jumpers. They do have varieties of Cables though. Maybe I should check out the DIY-Electronic-Parts section of the city to find both items.
The jumpers are standard 2.54mm ones. If you have an old hard drive it may be sitting there on the back - standard. The long jumpers I could only find on the Internet (Ebay). I am sure that you can find a source for just 10 of them.
