gibosi
- Oct 18, 2012
.......Like my Westinghouse plates looks similar to your Philco
I believe this is a Raytheon.
I have the ALPS Blue Velvet in the MK IV, I am not sure what is in the MK III.
A solder sucker or some dry wick will work good, the boards traces are fairly decent.
Hi TD, the volume pod is certainly a good point of action to improve SQ. Question, is the Alps Velvet the default MKIV volume control? Have you looked for a stepped attenuator to fit?
The Alps is the default control for the MK IV series, it is cheap and has very good channel matching.
The Dact CT2 on the other hand is an excellent attenuator, but with most 21 step type units I find there is always a time where the current level you are listening to is too low and the next click is too loud. This doesn't happen with a 48 stepped unit like the Khozmo or a 41 step unit like the Acoustic Dimension, unfortunately they are too big to fin in our cases.
Goldpoint has 47 step units that will fit, but they are only available in 10K and 50K which will not work.
Then there is this clown, selling a 24 step unit quoted as "probably the best attenuator on this planet". I really don't know about other planets and if there are better ones.
This is a Raytheon i have will check for Raytheon's also to match my Westinghouse .Thanks
I suggest for him to try Alpha Centauri or Kepler 438b for this comparison, lol.
Gonna stick with the Alps Velvet in the MKIV then.
Which planet is closer?I would like to go there and pick up the best POT/ATTENUATOR......
The closest planet to me is planet Partsconnexion 30 minutes away.
Hey guys...For those of you running 40's Ken Rad 6SN7s...Do you notice a vast difference (or any at all) between the angled and straight plate versions???
If "angled and straight" is your way of saying "staggered and parallel", I am not able to say... Based on comments and observations regarding these two Ken-Rad VT-231 versions in the 6SN7 Reference thread, I have purchased only staggered plate versions. And I can say that these are excellent tubes.
http://www.head-fi.org/t/117677/the-reference-6sn7-thread
Leaving earth on the Defiant would take you around 11 days to get to Terok Nor at a speed of 1816c since it is 52ly away.
Consulting with Stellar Cartography shows Cardassia Prime is 5.2ly away from Bajor and Ferenginar is 65ly away from Bajor. Since Cardassia Prime is only one more day away, it would be you closest location to pick it up in person.
You would have no faster way to get there than on the USS Defiant
