lemonjelly
- Feb 16, 2012
Thats exactly what i was told when i wanted to use my LD mk3 with my 70's Pioneer. I was told tough that the LD MK9 can be used with DC coupled amps .
Hi lemonjelly,
I have a DC coupled receiver that I cannot use with the MKIII. Do you know of any kind of circuit or outboard unit that can be added to block the high DC voltage?
Hi yep I think they included a DC protection circuit in the later amps. If someone wanted I would think you could do this yourself + add it to the chain. Probably there would be 2 ways of doing it, either after the DC coupled power amp with something like this (http://www.ebay.co.uk/itm/2X-Stereo-Speaker-protection-DIY-kit-Dual-relay-with-startup-delay-DC-protection-/221390943192?pt=US_Home_Audio_Amplifiers_Preamps&hash=item338bedb3d8) or after the LD with something like this (http://www.ebay.co.uk/itm/MINI-UPC1237-Headphone-Protector-Protection-For-Headphone-Amplifier-AMP-Project-/150784726223?pt=UK_Sound_Vision_Other&hash=item231b7854cf). They just kick in once the DC voltage gets above a certain level, so you're not using the circuit all of the time, but it just gives you insurance that your speakers will be protected.
I'd guess really that you'd be best using the speaker protection version as I wouldn't be sure what voltage would be safe to be amplified by the power amp (and would depend on the power amps volume/gain I would think). The other problem is potentially that the DC offset, even below a dangerous level might still be enough to degrade the sound (it isn't a good thing even in moderation).
Edit: just read a bit more about this (there's a good audiok thread if you google for dc offset blown speaker), so it seems you'll always have a bit of offset with a DC coupled amp anyway, and you can check to see how much that is with a multimeter. I suppose with the speaker protection board above, you would protect your speakers from any bad tube problems, and you could check what the DC offset is with/without the LD connected to see if the DC offset changes much, and use your ears ofc to see what you prefer.
