CollectoR13
- Apr 18, 2012
Wohaa waaaaay to expensive These tung sol XD
Didn't artsi use them as Power tubes on his mkii?
I am about to dive into the 6DJ8 pool due to an extremely kind offer from MIKELAP and is I go back and read through the thread when people started to use these I have a few questions.
With the Russian tubes 6N23P is it important to get the “P” version or will a 6N2P work as well, better? Worse?
I do not think there are enough Amprex 6DJ8 tubes to choose from LOL. Man I got lost! Is there a consensus on what “The” tube is? I am looking to not break the Bank so no I will not be spending a 1000$ a set.
To start I am looking for 1 individual to try under 50. Recommendation with link
Thank you
Gary
Received my voltage regulator today and am now using 6.3 volts DC to supply the heaters. And yes, it sounds fine. And I am hoping it is quieter, but will need more time....
Rummaging around the basement I found a 24 volt/400ma wall wart from an old cordless drill/driver which should be able to provide about 1.5 amps at 6.3 volts. (If I understand this correctly, we use the formula: Watts = Volts X Amps. So 24 x .4 = 9.6 watts. And then, Amps = Watts / Volts, so 9.6 / 6.3 = 1.5 amps). Much more than is necessary for the 6NS7.....
I anticipate that having a built-in voltmeter will be very useful if I want to roll 12.6 and 20 volt tubes in the future. And yes, that is a roll of electrical tape under the socket. The top of the transformer is quite slippery and the socket moves around too much for my comfort. The tape is somewhat sticky and figure it might isolate the socket somewhat from the transformer. And then a purple rubber band to hold the voltage regulator to the side of the transformer is just a nice design element, I think. lol
Anyway, now I am ready to roll 6NS7s!
IWith the Russian tubes 6N23P is it important to get the “P” version or will a 6N2P work as well, better? Worse?
Hi CollectoR13,
Buy these tubes from Yugoslavia; offer $4 or $5 each - free shipping. Asking price is $6.95. Look up on Ebay:
6HM5 /6HA5 / EC900 export quality audio triode tube / NOS / FREE SHIPPING /
As a bonus you will get a 1 second fireworks display when you turn on the tubes. (Don't worry, they are designed to flare up for quicker start, and it will not damage anything)
The 6HM5 is plug and play using the EF95 setting.
