Little Dot Tube Amps: Vacuum Tube Rolling Guide
Nov 4, 2013 at 1:02 AM Post #3,796 of 13,434
Managed to salvage a pair of B9A tubes from an old Rogers Console.
Rogers 12AX7 - I65 & r3L4 code which is Phillips Ontario.
Phillips MiniWatt ECC85 - tU3 & a "Right Angle Triangle symbol"4C3 code which is Philips Heerlen.
(Filament current possibly a little to high on the ECC85.)
Now I can play, I have a salvaged B9A socket and I'll make up some plugs for the LD's B7G sockets in the next few days.
Nov 4, 2013 at 5:14 PM Post #3,797 of 13,434
  Hi I love music 2,
There is much less of a selection of power tubes than driver tubes. The best are the 6H30Pi-DR/6N30-DR  tubes that today run in the $200-$250 range/pair. An excellent and much less expensive alternative is the 6N6P-IR that cost under $35/pair. Don't bother to look for anything else.
All these tubes are made in Russia. With the fall of communism the quality went down. It is best to look for older tubes made before 1990 and preferably from the 70's and 80's. Count on a month to receive them (sometimes faster).
Thanks  6N6P-IR is good enough i just need a spare just incase the one i have would give up.again THANK YOU.
Nov 4, 2013 at 6:27 PM Post #3,798 of 13,434
Received some Amperex Bugleboy 6DJ8  tubes today made in Holland .Now if i can get my sockets I will get started on 6 and 12 volts adaptors.
Nov 5, 2013 at 12:18 AM Post #3,801 of 13,434
Just test fitting a new design for the B9A adapter. I still need to wire up and epoxy the socket, make the pins and solder the unit together.
A little spit, polish, buffing and it will look good, even though it is a little too tall.
Nov 5, 2013 at 3:00 AM Post #3,802 of 13,434
All hail the chosen tube! Nice work sir!
Nov 5, 2013 at 7:13 AM Post #3,804 of 13,434
Thanks guys, it doesn't sound yet as there is still the hookup to do and that tube I just plugged in for looks. I think it is a heptode & triode combined and I just liked the screen on it. :D
Nov 5, 2013 at 8:30 AM Post #3,805 of 13,434
I made an adapter only for octals. Two 6N8S (6SN7GT) as power and one 6N9S (6SL7GT) to drive them. I think this is my cutest adapter and sound is so good that i can highly recommend this kind of thing to anyone. No any kind of hum or additional noise. Even cheapest Russian tubes seem to sound flawless.
Nov 5, 2013 at 4:01 PM Post #3,806 of 13,434
Nice configuration .
Nov 5, 2013 at 4:02 PM Post #3,807 of 13,434
Nice clean look love those tubes
Nov 5, 2013 at 4:47 PM Post #3,808 of 13,434
I'm so jealous!
Would you be willing to make one for my MK IV, if so PM me.
You pretty much turned it into the MK 9 http://littledot.net/forum/viewtopic.php?f=9&t=2537&sid=26e07a6b5e4b72fccb7c2aae7f5df775
Nov 5, 2013 at 6:31 PM Post #3,810 of 13,434
  Hi I love music 2,
Hi.
I recently got my Little Dot MkIII and found this nice guide. I'm new to tube amps but I already have few pairs of tubes to replace the mismatch stock pair of 5654's I got. I was wondering how 6N6P compares to 6N6P-IR soundwise? Saw them at 28$ pair so I might upgrade. Also there is these 6E6P-DRY/DRU tubes.. I presume they can't be used on little dot?
Thanks
