majkel
- Jun 1, 2007
Is there an anode voltage startup delay circuit in LD amps? AFAIK this delay saves tubes' lifetime significantly. Tubes don't like biasing when their cathode isn't hot yet.
Originally Posted by feifan /img/forum/go_quote.gif Misleading warranty statement: I just learned that David doesn't include tubes in his warranty coverage, despite this statement in his eBay ad for the MK III: "We offer a non-prorated (free labor, parts, shipping, etc) warranty covering all defects and labor for a period of one year." I haven't seen the MK IV ad, but I'm guessing he uses the same statement. One of the power tubes in my LD2++ went bad after seven months, and he refuses to replace them. He emailed me a different warranty statement which clearly states that tubes aren't covered -- unless they arrived DOA. I'm posting this warning here and in an LD2++ thread. Hopefully, your tubes won't go bad within a year. |
Originally Posted by feifan /img/forum/go_quote.gif You miss the point Wae5, and so did David. (The issue is the warranty.) Interestingly, you use the exact same arguments and examples as David -- which I didn't mention in my post. What are the chances of that happening by chance, Wae5? (The issue is one of credibility.) |
Originally Posted by sword_yang /img/forum/go_quote.gif Hi feifan, Please PM your address, telephone number, I will send the LD II ++ the tubes to you, all free of charge. |
Originally Posted by wae5 /img/forum/go_quote.gif There must be a chance greater than nil because I'm simply not David's shill- just a very happy customer with a lighbulb in my brain that was flicked on by your insinuating post. Lets see, what are common household items that are like tubes? Ah ha! Light bulbs and better still my three projector lamps which have warranties that are entirely separate from my projector guarantees. Light bulbs, PJ lamps and candles all burn down and no one (except David- see above) warrants any of these unless you're willing to pay a little extra and I've yet to meet the fool who warrants candles, but I'll be that fool if you're willing to pay a premium greater than the cost of that very precious candle and promise never ever to light it. |
Originally Posted by penguindude /img/forum/go_quote.gif Tubes do generally have a life span, around a few thousand hours (probably around 1000 for the LD2++ stock tubes). So depending how often you use your amp, the tubes may wear out faster than you think. |
Originally Posted by majkel /img/forum/go_quote.gif Is there an anode voltage startup delay circuit in LD amps? AFAIK this delay saves tubes' lifetime significantly. Tubes don't like biasing when their cathode isn't hot yet. |
Originally Posted by MaZa /img/forum/go_quote.gif Seven months for a tube is respectable if amplifier is used regularly. That shouldnt be even covered in warranty, they are meant to be replaced when they die (which usually takes couple thousand hours, hybrid-amps over ten thousand). Now, if a tube goes out in few days, not to mention the very moment you turn it on first time, that should be covered by any warranty. |
Originally Posted by wae5 /img/forum/go_quote.gif Apology accepted! Though I must admit I had a devilishly good time writing my response. Do you plan to try any of the new amps? The biggest change for you may be you'll no longer be able to fry eggs on LD's iteration of George's grill |
Originally Posted by feifan /img/forum/go_quote.gif Hey, I run the LD2+ with the faceplate removed. My concern was the jack -- I was worried about frying my expensive after-market HP cables. The plug doesn't seem to get as hot with this mod. I'm definitely attracted to the MK III and IV, and if they run cooler and others report no problems in the next six months or so, I'll definitely consider ordering it. I wish Sword would do something with the housing for the transformer -- as is, it has no style to speak of -- and offer a squarer version of the case. But performance will be the deciding factor. |
Originally Posted by vcoheda /img/forum/go_quote.gif those gold things around the tubes look ridiculous. do they serve a purpose other than masking the sweet glow of the tubes. |
