theryaner
- Jun 28, 2009
I just installed the OPA2107 today, and wow! HUGE difference compared to the 1364. This will definitely keep the skeptics on whether op-amps changes anything quiet. I literally just installed it about 10 mins ago so I won't write a huge report. But from what I can tell it's a lot smoother and less analytical than the 1364, good match with my grado 325is's. Music feels more organic and less "electronic" than the 1364, possibly more refined. To sum it it up, it basically has a similar effect to installing mullard tubes and will slightly sennheiser your grados.
@markkr
If you want more bass, I recommend these:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
These has a much more powerful presentation than my m8100's. I cannot comment on the tubes you're using but these might be what you're looking for.
@markkr
