You're absolutely right, DIY is hugely satisfying.
I only wish I'd forced myself to get started in DIY years ago. I've been contemplating it for ages, but having to learn all the electronics theory has always put me off. (I have an aversion to maths)
No question though, DIY is a huge, huge cost saver.
Right now my system is FLAC/foobar, from my chaintech AV-710 card via toslink into the DAC-AH, an Indeed Audio t-amp (a cheap eBay Trends knockoff), and Fostex FE126e based bookshelves, which are a sort of semi BLH design.
I've owned more expensive headphone & speaker rigs in the past (always CD based) but this one is the most satisfying, maybe because DIY is so much fun, and not having to swap CDs is sooooooo nice.
What about you? What are you future plans for your rig?
Also, where are you buying those Rubycons from if I might ask? I'm planning on replacing all the electrolytics in my DAC and was thinking of buying from parts connexion, but unfortunately all the have that's suitable are black gate standard caps which aren't the famous N class caps. They're still pretty expensive though.
Cheers for the advice on the regulators, I'm definately going to heatsink the DAC chips, replace those two regulators and run it at 8V - probably when I replace the electrolytic power supply caps as it will be easier to get in there will all the caps removed.
I'm also going to replace R35 and R36 was better quality 270 resistors, I was thinking Takman carbon films which seem nice and aren't too pricey.
Do you reckon there would be any sonic benefit to replacing the 24 reistors immediately to the left of the DAC chips with better ones? That's also crossed my mind.
