recca
DAC-AH might be old news with all of the new tech coming out these days but thought I would post some pics of my dac-ah finally running with battery power. For the mod I used a Pacific Valve modded dac-ah. First I removed the power transformer and the bridge rectifiers. From there I added a connector for an Audiomagus Powercenter battery power supply which has dual outs (the other output is for my Trends TA10.1). All you have to do is connect the + and - from the 12V connector to the corresponding ins on the board.
The other mods are the standard resistor mod and passive output mod. I kept the 6V regulators and changed the resistors to Riken Ohm Carbons 150ohm. For the passive output stage I used Jupiter Beeswax caps 2.2uF.
With Trends and dac-ah on battery power the system sounds pretty nice. Its been a while since I've had the stock dac-ah. I ripped the guts out a while ago but only recently finished the project so I can't remember what it sounded like before but I can say that everything is quiet which really makes it easy to hear the details. BTW - I'm not using it with headphones, just speakers (Aperion Audio Intimus 4).
BTW - Yeah I know the soldering sucks. I'm still a hack but at least it all works!
