LISA III Available for Order
Nov 18, 2009 at 10:48 AM Post #1,021 of 1,070
^^ indeed, as my fellow passengers on the bus sometimes will attest
....or is the protest??
Nov 18, 2009 at 2:46 PM Post #1,022 of 1,070
Originally Posted by rasmushorn /img/forum/go_quote.gif
I do not mean to interfere - but I can testify that the Lisa III can easily drive the HD650 to the stars...
[size=small]
That type of interference is definitely encouraged. Thanks, Rasmushorn and Qusp.
I know there are a number of small worthy home amps that can drive the 650's with aplomb. However, few (or none!) sport Phil's audiophile level bass contour functionality, which is so flexible and practical.[/size]
Nov 21, 2009 at 3:35 PM Post #1,023 of 1,070
I have communicated with the designer Phil on the RS version, and subsequently had the opportunity for a good, in-depth listen to this amp.
First, some introduction on the RS - according to Phil Larocco :-
Quote / Extract :
Unlike previous LISA III’s, The LISA RS is available in only the Home edition. Therefore the limitations imposed by alternate battery operation are removed because the LISA RS is an AC mains only powered headphone amplifier. The decision to keep the two Box systems of power supply and Amplifier is to allow the upmost in placement either vertically stacked one on top the other or placed side by side. Housing the Amplifier and power supply in separate enclosures also reduces the potential for hum and noise by virtue of shielding provided between the units.
The LISA RS takes the previous LISA XP and LAB POWER supply to the next level with circuitry enhancements that obtains the absolute highest performance obtainable from Phil Larocco's Buffered Op-Amp Topology. Additional circuitry refinements include operating the amplifier from high voltage power supplies. In the RS version The LAB POWER SUPPLY is set to provide 32 volts of Supper Clean regulated DC power to the LISA RS giving slightly over twice the power potential of the previous 24 volts in LISA III XP.
Taking full advantage of this improvement the amplifier circuitry was upgraded in several areas to provide more linear output current allowing operation into load Impedances one quarter the value useable with the previous LISA III’s at the same power and distortion performance. To avoid over-stressing the output transistors originally used in the LISA III’s, so these were replaced with the output transistors utilized in the definitive HEADCODE allowing the full benefit of the other circuitry enhancements to the listener. Large value reservoir capacitors occupy the space previously filled with batteries for substantial dynamic impact completely preserving every nuance and detail of the music.
With all these Improvements in power and output stages, it makes sense the voltage gain circuitry be also improved? How do you improve upon perfection? The original LISA III has utilized many unique and proprietary techniques to extract the utmost from the humble monolithic IC Op-Amp. Indeed a difficult task it is to improve upon this however, there remains one obscure technique described by Walt Jung, which reduces distortion in the Op-Amp by 10dB, and this was put to good use.
Unquote.
I took possession of a RS prototype in mid-October and have, despite a work-disturbed month, a good listen to it. I still have a special version of the original LISA III XP (in wooden case) with me so I was able to capture some obvious difference between the new RS and the battery powered XP. My prototype is still in the same LISA III XP and LLP casing so from the outside there is no markings saying it is a RS. I would expect the final commercial version will be marked as such.
In the car industry, the "R", "S" and "RS" are being prestigious suffixes of something special, and usually more expensive. I believe Phil wants to mean the same thing, though I am not sure about the pricing.
As good as the LISA III XP as a sub-$1K amp, I can almost immediately spot the difference when I listen the LISA RS, which is now probably the cheapest amp I have which have made the HD800 really shine. My first impression is instrument separation and overall imagine is improved. The RS is faster and more meaty - displaying astonishing dynamic response. Bass is more extended and better controlled. Decay and air are superb. It still shares the same DNA as the LISA III, only better in almost every aspect.
I am not sure of the official pricing, but was told it will be priced to be affordable.
Comparing to the other solid state and tube amps that I have owned and listened to, the LISA RS is a step above quite a few of them, including the Corda Symphony, Amphora SE, Woo Audio 6, Headphone Pro (even with the Little Pinkie v3i PSU), Lehmann Black Cube Linear, and the Graham Slee Solo (with PSU1), the Headroom Ultra Desktop (with Desktop Power Supply), the RSA Raptor, Grace M902, Lavry DA10, .... and others.
It is surprisingly close the the Rudistor RPX-100 (according to the notes I kept), which is now evolved to become the RPX-300. If the RS is priced below US$1,200, it can easily be one of the best buy as the last solid state headphone amp one may ever need. Compared to the Rudistor RP010B MKII (in single end output) that I currently own, the LISA RS is still a tad less in resolution and sound staging but that's probably all. I must say this is no shame as the Rudistor RP010B MKII is easily over 3 times more expensive than the LISA RS.
Is it perfect ? Well, almost. Phil does want the LISA RS to be the best achievable from a OP-AMP based topology and I would say he has his mission accomplished. But there are a few things that we should take note. First, the gain setting of my RS prototype is more suited to higher impedance cans. When I hooked the RS to the output of my Chord QBD76 (which provide an single end output of 3.7V), I only need to set the volume to less than 9 o'clock for a good enough volume on my HD800 and HD650. Using the Edition 8, I have very little play at the knob before it becomes just too loud. The situation does improve when I paired the LISA RS to my Nagra CDP ( which as a default output of only 1.2V). I am not sure if the commercial version will have a lower gain setting though. ( The battery powered LISA III has a gain setting to suit portable player like the iPod.)
Second, like the LISA III XP, the LISA RS is a single purpose machine - it has only one pair of inputs and does headphone amping only. So, feature wise, it is a bit lacking compared to others as a home amp ( multiple inputs, pre-amp out, SE and balanced out...etc.). Instead, the RS does the single job so well that one will have to shell out a lot more money to get above its performance as a headphone amp.
And one can certainly put in better a volume control (but that will tilt the price significantly). The one on the RS is good and I have no problem in channel tracking and balance, but I just can't stop imaging what this little gem can do if it comes with a better pot.
In short, for those who are looking for a compact desktop or home headphone amp, the LISA RS should be near the top of your list. I have enjoyed it tremendously.
F. Lo
Nov 21, 2009 at 9:02 PM Post #1,024 of 1,070
Thank you for that great review. It seems like a great new piece of hardware. I hope the price will be equal to the old LISA.
Nov 22, 2009 at 2:33 PM Post #1,025 of 1,070
Nice comments, fkclo. Thanks!
Nov 23, 2009 at 4:10 AM Post #1,027 of 1,070
Yes, LISA III is one of the best options to match the HD650 with very well sounding.
Nov 25, 2009 at 10:30 PM Post #1,029 of 1,070
Quote / Extract :
Unquote.
F. Lo
F.lo, you have basically named every desktop on my wish list (Isabellina a notable omission, but that is more expensive by several orders of magnitude) and said 'This is better'. Is it possible for you to start a new thread dedicated to the RS, please ?
Thanks,
estreeter
Nov 26, 2009 at 1:26 PM Post #1,031 of 1,070
Thanks,
estreeter
He hasn't named the Phonitor yet
. By the way, do you mean the Isabella? The amp of the Isabellina is the Amphora SE which F. Lo has already mentioned.
Nov 26, 2009 at 1:58 PM Post #1,032 of 1,070
Originally Posted by Remitrom /img/forum/go_quote.gif
Oops , camera dont work, uh, daa,, Will get help..
Brass on Black sure looks cool.. see soon..
Lisa RS , Desktop/home amp, (we just do not fit into categories neatly)
is now ready!!! & available!! When you get to the Lisa level of Sound Quality
it is hard to best, and improvements are measured in small degrees. To attempt this
Phil has nearly doubled the power, (removing the batteries in the process) now up to
home amp standards, added more capacitors & transistors as only he knows how.
And WALLA, the result is noticeable, slightly, in a word - MORE - just a little more
of what Lisa is already known for.. Of course source, cable, & can changes are
extremely obvious. Phil amazes me.. What can I say? Limited quantities
How to order? Can't find the RS on your website.
Nov 26, 2009 at 7:49 PM Post #1,033 of 1,070
The amp in the $2500 Red Wine Audio Isabellina is identical to the $995 Amphora ?
OK - $2500 Isabellina:
Products > Isabellina HPA - Red Wine Audio
Subtract the $1500 cost of the DAC:
Products > Isabellina - Red Wine Audio
And you have the =~ 1K amp:
ALO Audio
It all adds up - is this in black and white somewhere and I've simply missed it ?
I also like the Grace M902 (yep, its in there..), but it doesnt get much ink on Head-Fi. The Phonitor seems to be designed for studio use, and I wouldnt use most of it.
Nov 26, 2009 at 11:39 PM Post #1,034 of 1,070
The standard alone Amphora takes RCA inputs. The HPA can only take the output of the Isabellina and not source upgradeable so it should charge less than a retail Amphora SE. Apart from that, these two amps are more or less identical in performance.
Nov 27, 2009 at 2:24 AM Post #1,035 of 1,070
Thanks GreenLeo - looks like I need to wait for the RS along with everyone else. Will be eager to see the first couple of reviews.
