Liquid Links Cable Discussion Thread
Apr 11, 2023 at 4:08 PM Post #121 of 191
Swapped out the stock 2 pin with the ConX connector kit. Now I have both MMCX or 2 Pin to use with the same cable. I'm really impressed with this cable under the microscope. It has fibers that are encased in twisted conductors. In between the bundles of wires I also observed different gauges of copper strands. Good stuff man.
Interesting stuff! Where were You able to source conx connectors? Which solder did You use?
Also, how do you solder the wire on it?
Apr 11, 2023 at 4:34 PM Post #124 of 191
wasn’t aware they carry those.
And just be aware - effect audio 2pins does widen your pins in iems. So later you might need to change the socket. I experienced that on my QDC iem
Apr 11, 2023 at 4:57 PM Post #125 of 191
I can leave the 2 pin conx pins permanently into the IEMS and just unscrew them when I need to swap to other IEM's. I have 3 pairs each of MMCX and 2 pin connectors. So I'm pretty much set for a long time, since I don't have that many 2 pin IEM's compared to my MMCX collections of IEM's.
Apr 12, 2023 at 8:45 AM Post #126 of 191
Jun 8, 2023 at 9:33 PM Post #128 of 191
I recently acquired a Liquid Links Venom (2-pin, 4.4mm) and I'm quite impressed! Currently equipped on the MEST MKII (CIEM), I immediately noticed an upgrade in technical presentation. Fluidity, space and instrument separation remind me of my over-ear setup with this cable. Totally worth it, IMO!
I have a DIVA 2023 on the way and that comes with the Conti. Very excited to hear the IEM and cable! :)
Jun 25, 2023 at 12:15 AM Post #129 of 191
Does anyone know where to go to purchase the Liquid Links Conti, since Musictek does not carry it anymore.
There's mestudiobiz, I think they're based in Hong Kong.
Side note, seems like Liquid Links has a new version of their previous cable, Evua. Waiting to see what others think about it!
Jul 3, 2023 at 5:32 AM Post #132 of 191
I stumbled over a cable brand called "MELODY cable studio". They are using Liquid Links plugs and connectors. The prices are more affordable compared to Liquid cables. Someone knows if they are related or tried one of these cables?
Model: SNOW PRO 5N single crystal silver + 6N single crystal copper extrusion thick silver shield
Model: PURPLE True 7N OCC+Cross Copper Silver Plated Foil Winding
Model: MIRROR
Model: RAINBOW Copper Litz 560 Core
Jul 7, 2023 at 2:32 PM Post #133 of 191
Anyone here tried the martini with mest mk2 ? ( or if they could easily try would really appreciate some impressions)
Currently using stock cable with hiby RS6.
Jul 26, 2023 at 8:55 AM Post #135 of 191
Hi guys,
Which of the Effect Audio cables do you think can be compared to the LL Venom? I am considering the Code23 from EA and assume the Venom is better than the Code23. If someone has a direct comparison, please let me know.
Thanks
