New to the cable world.
I wanted to add more treble energy to my SA6 Ultra. Would the Westlake / Martini fit better?
Or am I crazy to pair a LL cable to an IEM at this price point LOL?
depends on pairing, and synergy, generally tho improves resolution and staging a lot (gives cave effect to the sound) imaging etc.. smooths out the entire sound, works really well with bright iems, smooth iems might be too smooth.
it can work with dark iems that aren't smooth, my plunge customs are v shaped, good chunk of upper highs and treble but are smooth, the venom makes them too smooth (which is the reason I'm selling the cable)
This Conti is best bang for the buck for top grade copper cables. I am surprised how soft this cable really is. Hooked up to the Kinera Celest and it's a perfect match when EQ'ed for bass.
Swapped out the stock 2 pin with the ConX connector kit. Now I have both MMCX or 2 Pin to use with the same cable. I'm really impressed with this cable under the microscope. It has fibers that are encased in twisted conductors. In between the bundles of wires I also observed different gauges of copper strands. Good stuff man.
