Digiti
- Sep 21, 2008
Using the open folder option in Ulilith navigate to the folder with the m4a files choose "all files" otherwise the file is not visible. It should play with your CCC codecs. You have a i7 which is multi core so core2 64 should work.I don't know what difference it makes in functionality or sound..give it a try you can always delete the folder if it does not work for you.
