pearljam50000
- Apr 7, 2013
delete
OK, so I have the geek out 1000 dac and it is a really huge leap forward in terms of sound quality for me (In my ignorance I have always been running Audez'e Lcd-3 straight off the pc/phone jack) and it sounded much better. However, I would like to ask if this setup enables the Geek out to be functional with a HTC one (m7).
The setup will be connecting a battery pack via a usb to barrel adapter to a powered usb hub, then connecting the phone to the hub via an usb otg cable, and finally plugging the geek out into one of the usb ports on the hub.
Also, will I need to use the usb audio player pro software? I was reading the other thread on usb dacs and Android, and the UAPP as well as UARP was mentioned as a software side usb audio enabler. Will default player work with the dac out of the box or do I need that app? Thanks for your time.
This was successfully done by our backers on kickstarter using a powered USB hub and UAPP which gave us the idea for the Geek Stream campaign (you should check it out)
Manny/Light Harmonic
How many hours does it need to be burned in?
And what is the best configuration in Jriver? Thanks.
HD800
And mine is GO 720 , so it's not as powerful as yours.
Are you unhappy with the performance now?
This is a personal bias, but I have never liked the results of running out of an amp to drive another amp. I think a true line level out is a better solution. For me, looking at something for desktop use, I consider a good standalone DAC feeding something like the Vali (or your choice of amp) might be a better solution than the GO driving the amp.
I have to say, because of my bias, and even though I have several standalone Headphone amps, I have not even tried driving any of them with my GO. I only have used it directly driving the various headphones/IEMs that I use. I does what I need from it in that role and it does it without having to drag another box, power supply and cables around.
