Light Harmonic Geek Linear Power Supply (LPS and LPS4) Impressions/Discussion
Apr 19, 2015 at 5:26 AM Post #64 of 81
  What about the plug situation for international shipping? Cause I remember they changed to all standard US plugs because of the port situation.
Since I´m an international backer too I asked about this (in my case Source and ViDac) in conjunction with the survey.
Answer from the Customer happiness team was that only US plugs will be provided. Guess this is also valid for all other devices including the LPS/4.
http://lhlabs.com/force/customer-happiness-post-concerns/3871-continuation-of-new-survey-comments-and-concerns?start=325#63483
May 11, 2015 at 3:52 AM Post #65 of 81
It looks like the Pulse Xfi is currently shipping with a switching power supply that works with 100-240 V.
http://www.head-fi.org/t/687851/geek-pulse-geek-desktop-dac-amp-by-light-harmonics/7200#post_11587163
I have no idea what kind of power cable currently ships with the LPS for non-USA units though.
[rule]
I just watched this today and thought it might be interesting to some of you who might want to know a little more about what goes on in a linear power supply. The video isn't focused on LPS designs per se, but rather why multiple parallel capacitors are often seen in electronic circuits, including LPSs.
[video]https://www.youtube.com/watch?v=wwANKw36Mjw[/video]
And for those who don't know what a full-bridge rectifier is, or why capacitors are needed in a LPS:
[video]https://www.youtube.com/watch?v=sI5Ftm1-jik[/video]
^ that guy is awesome
Dec 13, 2015 at 2:19 PM Post #67 of 81
Can I use the Lambert Play it By Ear Tube amp through my Geek LPS 4?
Specifications:
  1. Load:                                16 ohm – 300 ohm
  1. Output Power:                  100mW @ 32 ohm
  1. Power Supply:                  19 volt DC LAMBERT Model, supplied
  1. Vacuum Tube:                  1 x 12AU7 Twin Triode.
  1. Output:                              1 x Single Ended Class A Mosfet per Channel.
  2. Product Dimensions:         105mm Wide x 154mm Deep x 10mm High
Dec 13, 2015 at 2:35 PM Post #68 of 81
[COLOR=666666]
Specifications:
[/COLOR]
[COLOR=666666]
  • Load:                                16 ohm – 300 ohm
[/COLOR][COLOR=666666]
  • Output Power:                  100mW @ 32 ohm
  • Power Supply:                  19 volt DC LAMBERT Model, supplied
  • Vacuum Tube:                  1 x 12AU7 Twin Triode.
  • Output:                              1 x Single Ended Class A Mosfet per Channel.
  • Product Dimensions:         105mm Wide x 154mm Deep x 10mm High
[/COLOR]
I would say no, unfortunately because of:
The Geek LPS only supplies 12 VDC from its outputs.
Mar 20, 2016 at 9:48 AM Post #69 of 81
Does anyone know what the amperage and type, fast or slow blow, the fuse is for the LPS4?  I know it's 250V rated.
Apr 17, 2016 at 10:03 AM Post #70 of 81
Does anyone know what the amperage is for the 5V output? I cant find any precise specs on that one...
Apr 17, 2016 at 10:38 AM Post #71 of 81
The USB Type A 5V is rated at 0.5A.
Oct 31, 2018 at 11:49 PM Post #72 of 81
http://lhlabs.com/force/customer-ha...-survey-comments-and-concerns?start=325#63483
Yes I know this is an old thread but thought it might still be helpful to someone out there in Head-Fi land. I have the LPS and the LPS4. The LPS shipped with an Aussie power plug. The LPS4 I imported from the US of A, and as you would expect it came with a US of A plug.
J.
Jan 17, 2019 at 1:42 PM Post #74 of 81
1C39BE7A-C1DA-4B15-8146-144DFCE6B840.jpeg Any idea if I can power the Burson Fun amp with my lps4?
https://www.bursonaudio.com/products/fun/
