So, as it stands, the list of DACs I'm going to attempt* to audition, along side Yggdrasil, right now are, in no particular order, as follows:
MSB Analog, Select & Diamond
TotalDAC
Chord DAVE & Hugo TT
EC Designs Mosaic T
Metrum Pavane
PS DirectStream
And then just to see if things have changed, synergy wise, I may revisit the Auralic Vega and add the Audio-gd Master 7 (though I'm still not a PCM-1704 fan).
As per my original post, my
default purchase decisions is
another Yggdrasil. It's stood up to everything else I've been able to listen to so far and bested even the more expensive units in my opinion (things like my Akurate DSM and a Merging NADAC).
While there were lots of DACs mentioned both directly, and in some of the lists that were linked, the input on which I am genuinely grateful for, I found that as I did more research on them I was ever more turned-off by the "off the shelf DAC chip" approaches coupled with excessively fancy clocks or super-quiet power-supplies (that wind up sitting next to a tube stage with 10,000x higher noise levels) or "for the sake of it" tube buffers/analog stages that wind up costing $30K.
I do have some odd quirks when it comes to how, and on what, I'll spend my money. *The first of which is that I will not jump through endless hoops to do it. If a company wants me to buy their product then they need to make it easy for me to do (that's true whether I'm spending $10K on an audit component or $20 on lunch). Whether this is having a solid dealer network, or offering home-trials, I don't care.
I expect I'll have to face some DACs off against each other rather than against Yggdrasil directly, before being able to compare the winner of that face-off to Yggy.
And once we're north of about $10K, the DAC will have to be immediately and obviously
better (not just "different") to it's cheaper peers. I'm not going down the brain-burn-in route nor worrying about differences that are so subtle they take hours or days to become apparent. Raw cost is not a big factor (I didn't see any DACs listed that I couldn't just write a check for), but value will become so at some point. I value aesthetics - but I'm not paying $20K for a pretty case on $5K worth of electronics
Finally, when it comes to actually buying, I'm not going to deal with enormous waiting periods. If I am paying up-front, then you've got 30 days to deliver. If you're just taking a small, refundable, deposit, I might wait 90. More than that, and too much can change and my patience will falter.
