SoundAround
- Jul 8, 2016
Hello @Torq:
One of the records in the table reads “Bristol BDA-3”. Should it be changed to Bryston BDA-3, perhaps?
This reminds me of the controversy over Schiit's Gungnir and Yggdrasil SE vs balanced outs. Your comments above would suggest that for Yggdrasil there isn't much of a drop in performance when going SE...
One minor request, if you would consider: Many of the components you evaluate are available from dealers with no price tag readily advertised on their website. It would be nice if you could mention the dealer's asking price for the components you review. This way readers can more easily judge on the value merits of the product in question compared to the Yggdrasil...
And one very minor remark, if I may, @Torq.![]()
One of the records in your table reads “Bristol BDA-3”. Should it be changed to “Bryston BDA-3”?![]()
Torq, have you listened to the Gumby? If so, what do you think about it? I realize that this thread is about finding an upgrade over Yggy but I thought it would be interesting to hear your thoughts about it's smaller sibling.
Very curious of your opinion of the Pavane vs Yggdrasil will match the others I have read.
I have simply been using usb since its implementation is not bad but From my Imac I will try toslink tonight to see if I hear a big difference.
It's coming ... probably not today, but it's coming.
I didn't try the Pavane with USB (or any other DAC that had a USB input unless I was testing DSD or it was the only option). For TOSLINK I like the Lifatec cables; they're inexpensive and measure way beyond spec (way beyond anything that I'd ever imagine will be relevant to audio in fact).
Ill have to pick up one of those cables.
BUT if you prefer AES on the yggy you may like to use ethernet via the Rednet 3. However using extra software etc is a turn off to me.
