I'm not big on DSD, but would love to help if possible. I'm a Mac user, who owns a Mojo and recently acquired a Hugo. I also love my Yggdrasil, and am curious what you find through your endeavors.
I was able to play a sample track of DSD 2X only by quitting every single application except Audirvana+. I also changed the Native DSD Capability pull-down menu from Automatic Detection to DSD over PCM standard 1.1. Only then was I able to play beyond DSD 1X without drop-outs. I assumed this was because my Mac is several years old. However one or more of these steps may help?
I certainly appreciate the input!
On the very latest, absolutely maxed-put Mac Pro, even with nothing else running and an array of other system services shutdown (including things like disabling WiFi, Bluetooth and so on ... that are not viable to turn off in general usage), and removing every other USB device from the system, even in explicit DoP 1.1. mode, I still get dropouts for 2x DSD ... less frequently than for 4x, but still its not usable.
I'm 100% sure the issue isn't down to processing power (you can't buy faster OS X hardware than that I'm testing with). But, to verify that, I created a file that has already been converted from DSD to a DoP file. In otherwords, its PCM frames actually contain the already-converted DoP format sample data. This eliminates any play-time processing overheard. The file is simply streamed directly just as it if was a PCM file - at much lower bit-rates than I can otherwise send data to the Mojo.
Incidentally, the processing required to create that file was something that an average SmartPhone could do at several dozen times the speed necessary for real-time playback.
I couldn't get the thing to dropout at all playing to an Auralic Vega using DoP 1.1 and there were no audible artifacts or other indications that it wasn't working perfectly. I even fired up multiple video rendering paths and ran a heavy VM-dependent, code build while the Vega was playing, and that was 100% solid with DSD128 (i.e. 2x).
I've tried multiple machines, all more than powerful enough to do this work in real-time, with multiple USB cables (all of which test to, or above, spec), DSD files from multiple sources and so on.
I truly do appreciate the suggestions though!
I'm not particularly a DSD fan myself. I've yet to hear it beat PCM in any demo I've sat in. It's telling that my first experiences attempting to play with it properly at home have met with issues. And it's not like I'm a dummy when it comes to hardware or software (I do pretty serious engineering in both spaces). But I did want to see if DSD could, on appropriately equipped DACs, offer something that isn't available with PCM.
So far, it seems like the answer is "no" ... but it's too early to realistically tell ... just the hassle in finding out is rapidly turning me off the whole notion.l
Certainly none of the single-rate DSD files I've purchased sound any different to me, through the same DAC, when played either natively or after conversion to PCM. And where I already had PCM versions of albums for which I've since bought DSD versions (again, to test with) the DSD versions haven't yielded any benefit over even their simple Redbook versions. Maybe that changes at DSD128 or DSD256, but I can't get the music to play without dropouts for long enough to make a useful determination.
I had high hopes that the Chord DACs were going to give Yggdrasil a run for the money. The Mojo certainly punches well above it's price range. But I'm highly disinclined to buy any product that I cannot utilize to it's full extent and even less so if I don't understand why there are issues when things work fine elsewhere. Maybe Chord will come up with either a solution or a suitably coherent explanation ... if so I will gladly keep the Hugo TT and the DAVE on my audition list. If not, I've no reason to bother.
I've had a PM or two suggesting I just run Windows instead ... but that's not going to happen - much easier for me to just choose a DAC that works completely with OS X and doesn't have unreasaonble configuration requirements beyond that (not that I've found a configuration that works yet).
