LightBlue77
About android 10, i tested again with one plus 7 pro but as I said, i expect the same on v40, dsd playback is possible via uapp if native dsd mode is checked on usb options, both uapp and dac show dsd 256 sample rate.
Yes.Hello,
Hifi-Mode = standard
Aux-Mode = mid gain
50Ohm HIM = high gain.
To force aux just unplug the left connection of your headphone.
To force HIM (high gain) you need a short extension cable and a >50 ohm headphone or an adapter above 50 ohm.
Plug the extension cable with the adapter or >50ohm headphone in the jack, than unplug adapter/headphone from extension cable and connect your preferred headphone to the cable.
Is it safe to do this at all?
Thank you.Yes.
Both smartphones (V30 - V40) are sharing the same audio soc, V50 also.
Mh.Thank you.
Can I ask which extension cable and 75 Ohm adapter is good?
Thank you.Mh.
Any extension cable could do the job.
I bought a cheap 4" extension cable from amazon first but have bought the Grado extension cable short after.
Grado Mini adaptor cable
An angled hard adaptor 3.5 to 3.5/6.3 is suitable as well.
Don't know which 75r adaptor works well bc i'm trigger the HIM with my old AKG K530 headphones.
Thank you.Just unplug the cable on the left cup of your headphone.
Plug the 3.5 mm cable to the V40, it'll show hifi.
With the app hifi status, it'll show "aux".
Than attach the cable back again to the left cup.
