RishiGuru
- Dec 24, 2010
Just out of interest, is there a 'better' LG phone than the LG V30 in terms of sound quality?
I haven't listened to them all, but the V30 through the V50 all used the same audio hardware/DAC so I expect they are similar. The V60 uses a different Sabre DAC and lost MQA compatibility.
LG's Quad DAC is ESS ES9218P audio chip. In any LG marketing material if you find the use of Quad DAC it implicitly means ES9218P. The ES9218P was first used by LG G6 (Korean & Indian versions). Later it was implemented in all of their flagship G & V series models. Starting with V30/V30+/V35 then G7/G7+ then V40 then G8 then V50 and finally ending with V50S/G8X. The only difference between V50S & G8X is the former supports 5G networks. For the latest V60 we have the newer ES9219.
Audio tuning house of ES9218P varied from time to time & model to model. G6 & V30 lineup were tuned by B&O, G7 was tuned in-house while V40, G8, V50 & V50S/G8X were all tuned by Meridian Audio.
Regarding audio quality the sound signature of Meridian tuned G8X is dramatically different from my B&O tuned LG V30+. V30+ tuning makes it analytical sounding with an acute knack for detail retrieval. Meridian tuned G8X is more musical and forgiving on headphones while sounding lush and vivid but not loosing anything in terms of details. G8X sounds more like my Vivo NEX S. There is a spatial spaciousness in G8X sound signature which makes for big soundstage on a horizontal plane, while that of V30+ is on a vertical plane. Both V30+ & G8X have their pros and cons in terms of audio quality as both audio tuning houses have their own preferences. Personally I like both.
My G8X came pre-installed with Android 10. My only gripe with Android 10, LG have stopped supporting native DSD audio playback in the software layer. But with more common PCM audio (FLAC, APE, MP3) there are no issues. I don''t care my G8X have no MQA support. Never use it.
I do not want to stick with Android 9 on G8X. LG's Dual Screen concept is in its infancy with many rough edges. Every software/ firmware update brings significant improvements in overall software experience & intuitiveness on G8X. Over 2 years time when this concept gets matured we can skip Android version upgrades as the delta of overall improvement will be much less.
During Diwali sale, brand new G8X with Dual Screen slapped in were retailing for just $245 in Flipkart (owned by Walmart). Bought one at at a heartbeat. LG's are pretty cheap here, my second V30+ was for $150 brand new.
