W1ll1eTheP1mp
What is an good upgrade from IE800 or something similar/worth trying if IE800 is your go to IEM?
Its ships on Saturday or monday . an DHL says 8-16 days in shipment. Graph looks great. If u contact them now they maybe have some left with discount
I played around with custom ROMs a while back (both 9 and 10) but ended up back on stock Pie, bootloader unlocked and rooted with Magisk. This way everything works, Netflix HD, FM radio, etc...
If you are like me you'll probably try anyway... Good luck!
Don't upgrade. Android 10 breaks bitperfect DSD playback.
Thanks guys! My V40 is European and unlocked. I managwd to stop the android 10 update when it was 5% downloaded ( That was lucky since i was asleep when the update came a month back). Is there a way to remove that prompt? Cause it is showing on my alerts all the time and its a little annoying. Tried to google but it seems i have to backup my phone to google disk or something and turn of auto updates. Then install the backup? I habe never tried DSD files before.Hello! Has anyone here decided to go with android 10 instead of 9? I have 9, but im a little divided if i should update or not! Want some tips
Here's my answer: **No freaking way** would i do it if not forced by my carrier--which unfortunately I was with my V40. As mentioned above, LG screwed the pooch with the A10 upgrade as it messes with DSD--more specifically it will no longer play them natively and will instead convert to PCM. Why the hell would i want to do that??
I also hate the bloated app changes---like the blobby camera interface and to me it just seems more dragged down now.
I almost tried to hunt down an unlocked V40 just to avoid this---but decided there's just too much choice of new devices (including the Wing) now.
Will it show as DSD on UAPP? Maybe i have to try the free DSD files and 2L recording site and check if there is a audible difference to me
Do you guys hear the difference from flac and DSD? How and where do i get DSD music except from nativedsd.com( is it that the site is called)?
And at last: Is there a different app like uapp that i can use? Is that neutron? I meant that i have read that there is another app that lg quad dac users use and some says it sounds better? Just curious of the UI. Im dependant /want a "similiar artist/album" funtion.
