good sound
- Feb 23, 2013
Correct. Headphone cable into adaptor, into extension then into the phone.
Has anyone tried Ety Kids with this phone? Extremely low volume here. Funny considering they drive HD650s. Thanks!
Quick question that's probably been answered:And just to confirm are you plugging the extension into the phone last, after connecting the impedance adapter and headphones to the extension cable.
Why do you need an extender? Also, do you need to keep everything hooked up or just trick it once and then plug headphones in directly?
How high does the impedance need to be? So you connect headphones, impedance adaptor, and extension together first, then plug into the phone, play music, then take out the impedance adaptor and plug the headphones straight into the extender?The extender is used for a couple of reasons
1. to trick the system into playing in Aux mode as that seems to be the default mode with no load. Then you can plug your IEMs or headphones into the extender
2. The extender is part of the chain so once you've "tricked" it into a higher impedance mode with the impedance adapter and your iems or headphones all connected, you can then take it apart so you're able to remove the impedance adapter.
Another alternative to this is if you are able to root your phone is to edit the mixer paths file as described in the LG V10 thread (A search of that forum for the word mixer will find it quickly) Then no adapters etc are required.
Have fun.
