saj2001ind
- May 2, 2014
The andromeda is around 12.8 ohms. I don't really care if all four dacs are activated. 4 doesn't necessarily better 1. If they push out too much voltage it'll ruin the sound too anyway, plus you'll have little control of the volume. Using it I'm aux mode would just push the highest power it can. With sensitive iems this could damage it.
I have tried and tested G6 for 2 months with all aux adapters etc
Fact is unless g6 dac doesn’t goes to high impedance mode the sound quality is not good along with volume
Compare it with any ESS dac DaP with your same headphone and Then with G6 you will experience the difference
LG should have given a simple option to switch on and off the full power of dac not do this automatically which kills a fantastic music phone
