saj2001ind
- May 2, 2014
Anyone compared with fiio x7 ii can post their experience pls
9028 PRO vs 9218. That would be interesting to know. Personally I believe that the G6 with a good amp can outperform the X7 II, but this is in theory only.Anyone compared with fiio x7 ii can post their experience pls
Which amp ?9028 PRO vs 9218. That would be interesting to know. Personally I believe that the G6 with a good amp can outperform the X7 II, but this is in theory only.
The G6 needs something like the FiiO A5 to shine in the soundstage department. It's amp related.Hi everyone.
Got my G6 Plus 3 days ago and been testing it and comparing it to my HTC m7. compared to HTC m7, G6 has much less bass and soundstage.
But high frequencies have much greater clarity and control.
overall a pleasing sound signature that is great for hi fi audio, instrumentals, and concerts. i would still prefer my m7 for modern day music.
https://docs.google.com/forms/d/e/1...lGjlqFxNBp-H4Enq4OXNlQ-jSu-VYww/viewanalyticsJust a quick question. How long does it last on a battery with screen on full time.
This is a common issue with devices mass-manufactured for base consumers.I am finally selling it to get fiio x7ii...listened the x7ii and it's mind blowing awesome and has simple options to control all DAC features
The software on G6 has killed this great audio phone ... Too bad even V30 suffers from these nonsense setup
Bye bye LG phones now
What is the ohm of your headphone ? If it’s less G6 will not use full potential of its ESS quad dac and will show normal device connectedPlanning to snag the G6 just because the prices on it now is pretty good. Just a few questions...
1) If I'm planning to use my Campfire Andromeda on these, I'm assuming it'll just use one day since they are low impedance?
2) The dac that will be used would be the ESS dac, not the SD dac, yes?
3) All I need to make sure I'm using the ESS dac would be to turn on the hifi mode, and that's it?
This is the major drawback of G6 or even v30 ... they should give an option to manually select full dac mode
Typically headphones with 50 or more ohms only triggers quad dac with full potential else lower doesn’t takes its advantage and to me they doesn’t sound as good as high impedance ones
