DrewVz
Worked for me. Thanks! Might be getting mine in a few days.17track.net works well for me. What's your courier?
Thanks for your inputs! How do you thing they'd perform from a LG G8 a 3.5mm jack?I have found though that they much prefer the 4.4mm on my HiBy R5 to the 3.5mm.....they do like juice.
I don't have mine yet but I have an LG V20 with the quad DAC. I imagine that because of the low impedance, it won't trigger the high gain on the LG's and might be lacking power.Thanks for your inputs! How do you thing they'd perform from a LG G8 a 3.5mm jack?
I have the LG V30. I'll put a 3.5 adapter on the 4.4mm Shuoer cable in the morning. That should trigger the High Res DAC and I will tell you what I hear.I don't have mine yet but I have an LG V20 with the quad DAC. I imagine that because of the low impedance, it won't trigger the high gain on the LG's and might be lacking power.
So this morning I attached a 4.4mm to 3.5mm adapter to the Balanced 4.4mm cable I got with the S12 package to my LG V30. Any attached adapter forces the LG V30 or other LG phones with the Hi Res DAC into Hi Res mode. I listened to Tidal HiFi Streaming and Amazon Hi Res Streaming, and there seems to be plenty of juice to drive the Shuoer S12. On my HiBy R5, in particular, the 4.4mm balanced drives the S12 really well.....they seem suited to each other.I don't have mine yet but I have an LG V20 with the quad DAC. I imagine that because of the low impedance, it won't trigger the high gain on the LG's and might be lacking power.
Thats great, but how di*erent are they from one another?Close to 180hrs how crazy good it sound. Really like s12 and timeless. Both affordable and sound good.
Thanks for the feedback!So this morning I attached a 4.4mm to 3.5mm adapter to the Balanced 4.4mm cable I got with the S12 package to my LG V30. Any attached adapter forces the LG V30 or other LG phones with the Hi Res DAC into Hi Res mode. I listened to Tidal HiFi Streaming and Amazon Hi Res Streaming, and there seems to be plenty of juice to drive the Shuoer S12.
Their timbre don't sound alike at all. Has deeper soundstage, clearer details and bass more punchy than timelessThats great, but how di*erent are they from one another
Ok I might be wrong, but I'm pretty sure you don't get the balanced output if you put a 4.4 mm balanced + 3.5 adapter into a SE source (I believe the LG V30 is just SE). If you don't have any sources with balanced output, you should only get the 3.5mm cable option.Thanks for the feedback!
Based on your experiment, should I go with the 4.4mm balanced cable S12 + 4.4mm to 3.5mm adapter? If so, which adapter would be the best option? There are so many models! Any recommandations?
Ok! I have the LG G8. I'm worried that the 3.5mm cable option won't trigger Hi Res mode. What is the best option between 4.4mm with adapter or 3.5mm cable?Ok I might be wrong, but I'm pretty sure you don't get the balanced output if you put a 4.4 mm balanced + 3.5 adapter into a SE source (I believe the LG V30 is just SE). If you don't have any sources with balanced output, you should only get the 3.5mm cable option.
With the LG V30 and probably the LG G8, to get the High Res mode guaranteed working is to add an adapter or short adapter cable length to the IEM cable. If it is a 3.5 cable you use then you will need a 3.5mm to 3.5mm adapter if you have a 4.4mm cable you will need a 4.4mm to 3.5 adapter (which is what I used). Never use a 3.5mm single ended to 4.4mm balanced, that way round, as that can cause some damage. The Hi res on the LG phones can drive most IEMs quite well......if you don't have an AMP or DAC with a 4.4mm balanced. My own phone the Sony Xperia 5ii does not have enough juice to get the best out of the Shuoer S12.Ok! I have the LG G8. I'm worried that the 3.5mm cable option won't trigger Hi Res mode. What is the best option between 4.4mm with adapter or 3.5mm cable?
Sorry, don't want to highjack the S12 thread!
Sorry I don't know about LG phones specifically. You might want to search for the power output of LG G8 3.5mm jack. LG V30 has 2 vrms on high gain, which is quite a lot. I think a cheap dongle might do 1 vrm.Ok! I have the LG G8. I'm worried that the 3.5mm cable option won't trigger Hi Res mode. What is the best option between 4.4mm with adapter or 3.5mm cable?
