It isn't a "problem" that is universally hated by everyone, just because you don't like it doesn't mean there is something wrong overall that Letshuoer needs to change because they messed up.
This is not the first time I have seen complaints that aggressively formed heat shrinks at least push the shells out of the ears. And this leads to worse noise insulation and, as a result, weakened bass (of course, there are more high frequencies than necessary).
Cut the shrink, change the shape with heat of buy a new cable and YOUR problem will be solved.
Already cut off the heat shrink. But because of this, now the cable behind the ear rubs even more and is not fixed behind the left ear at all. I have to really tighten the slider under my chin, which feels like a noose around my neck. That is, it became even worse than it was
And yes, I still think it's idiotic to take a pair of scissors or a hair dryer and try to fix something on $135 USD in-ear headphones! These are not unknown cheap headphones that cost a measly 3-5 dollars, so they can be forgiven for this. These are audiophile-famous in-ear headphones from a reputable brand that cost
$135!!! And yes, I am aware that there are in-ear headphones that cost 1000, 2000, 5000 dollars, but this does not change the essence of the matter. Having bought them, do I still have to tinker with them, cutting or heating something?
Seriously???
And buying a separate cable for them at the price of the headphones themselves is even more idiocy! The price of the S12 Pro itself also includes its modular cable. Why should I buy something else for in-ear headphones that already cost a considerable
$135?! In addition, we must not forget that the third-party cable still needs to be selected correctly, because it can change the sound for the worse. And this is again a lot of wasted time and money going through all these audiophile cables. In this case, I'd rather sell them and buy something else that will meet my expectations.
And yes, I perfectly understand that the fanboys of Letshuoer products are mostly gathered here, but you should always remain objective and approach everything with a cool head.
…how can Letshuoer or anybody else provide a type of ear hook and its exact shape that will please everyone, they can't, get over it.
At least companies like
Sennheiser,
Sony and
Shure have the answer
Are you sure you have ear tips that provide a proper seal and a
secure hold ?
The tension from a tight radius heat shrink ear hook shouldn’t literally pull the IEM out of your ears if the tips sit firmly in your ears.
I use the included medium-sized white silicone tips. And yes, I have the most ordinary, average ears.
