behemothkat
@Tronsmart Official is it possible to correct application to avoid after 1st time paring/connected every time asking to select between Apollo and Spunky? It is VERY annoying.
Hi,@Tronsmart Official is it possible to correct application to avoid after 1st time paring/connected every time asking to select between Apollo and Spunky? It is VERY annoying.
Hi,The Android app doesn't work. It prompts "Download failed" in italian when I try to update the Apollo firmware. Tried it several times without success. Please fix the app. I had to purchase an qualizer app in the Play store 'RE EQ' for 3 euros!
Hi,@Tronsmart Official other question: do you plan to introduce APTX HD with some next fw update?
Thanks for update!Hi,
Actually we have planned with Qualcomm, Qualcomm QCC5124 can support aptX HD, but in speaker it is OK, in TWS earbuds, there are still technical difficullties, we are still working with them to see if we can overcome it! Thanks for your understanding!
Last application update got this bug fixed. But now unstable works switching between ANC off/on/ambient modes in app - once it stopped to work I need to reconnect TWS in app again to restore it working.I tried to customise my touch actions, I can’t find the way how to save changes.
As long as menu opened my TWS changed control working, but when I am exiting to EQ tab or home tab or exiting from application, settings reverting back to default.
Hi,Hi,
Hi,Hi, can we use 233621 Zen App to update the OTA ?
