Crashem
- Feb 5, 2014
How do you compare in sound 6x5 rectifiers Bendix to OTK ?
You should definitely try both as it is really different in obvious ways. I think I commented on it earlier, but I will give quick synopsis. With Bendix, the soundstage got A LOT larger but your listening perspective was moved back a few rows (think row#4 as opposed to being on stage). As such, bass wasn't as in your face. Wouldn't say it was less bass with Bendix, but you are listening it from further back if that makes any sense. Also, I think the higher frequency dynamics are better with Bendix, but that is much more of a subtle thing.
The Tung Sol 6x5 seemed to bet somewhere between OTK and Bendix so worth a listen.
Going to be testing a ton of different 6x5 (since I was previously unfamiliar with the 6x5 tube) in my L5. Rolling the rectifier seems to have paid more obvious sonic changes than rolling driver tube (6sn7 in my case).
Is there a particular sound you like so if I hear a 6x5 that might suit you, I'll send the recommendation your way.
