Tjj226 Angel
- Oct 20, 2012
I have no update on the phono stage just yet, still planning to powder coat tomorrow, but I have some down time at work, something has been on my mind...
I am fan of Nelson Pass, I admire his balanced approach to designing his amplifiers that blends both objective measurements and subjective impressions. He has also been a huge supporter of the diyAudio community, and he is just a cool dude IMO.
Obviously Nelson deals in solid stage gear, and I am a self-proclaimed "tube guy", HOWEVER, I have been very intrigued by his First Watt line of amplifiers for some time as they incorporate many of the same philosophical design goals sought by tube SET nuts like myself, that being simplicity of circuitry, pure class A, and minimal NFB.
I'm sure some are already familiar with First Watt, but it is essentially Nelson's experimental playground where he designs what he wants outside of the Pass Labs brand. Of particular interest to me are his designs that utilize static induction transistors (SIT), also known as VFETs. What makes these devices very interesting is that their characteristic curves are much more similar to that of triodes than your typical transistor, whose curves are more similar to that of pentodes.
Why is this important? Because triodes / SIT transistors can be operated in class A without feedback at reasonable levels of distortion, whereas pentodes / JFETs / MOSFETs are much less linear and require NFB to tame their distortion to acceptable levels when used as voltage gain devices.
Below are the curves of one of Nelson's SIT transistors, as you can see, they are much like that of a triode.
Anyway, why am I ranting about all of this...an attractive project for me is to build a tube preamp and pair it with a First Watt SIT amplifier...except the First Watt SIT models are essentially unavailable as the SIT devices were made in limited quantity, and they went for around $4,000 a piece!!! BUT Nelson intermittently releases kits to the DIY community, and he happens to have one coming up that utilizes NOS VFETs. I am going to try and get my hands on one when they are released, and if so, I will build it and perhaps pair it with a tube preamp.
Long story short, I might build a DIY SS power amplifier, assuming I can get one of the kits. If not, perhaps I will build one of Nelson's other DIY designs, we will see.
Will hopefully have some powder coated phono stage chassis to show off tomorrow![]()
I have looked at doing the same thing a few times. Something that you might want to look into are the Russian SIT/Vfets. I haven't looked to see which parts are good and which ones are bad, but they are generally cheaper and somewhat readily available.
Couple other things worth considering.
1: Super triodes. If you are going to make a hybrid amp anyways, take a look at super triodes. You can get tube curves, with SS power, for a fraction of the cost of an SIT part.
2: Feedback. There are supposedly different ways you can introduce local feedback to a mosfet to make it act like a triode.
3: Push pull with identical parts rather than complementary parts. If you take the time to design an amp with two identical output devices, the distortion characteristics will cancel more completely than if you had used an N and P channel complementary pair. This means that the majority of your distortion will come from your single ended driver ie your tube front end. Also worth noting is that with a bipolar PSU, feedback, and DC offset, you can eliminate the output capacitor. And trust me, a DC servo circuit is WAYYYYYYYYYYY cheaper than a high quality output capacitor.
A SIT amp would be cool. Any of the other options are cool too. Just want to give you some options before you see the price tag on the SIT parts : P
