Yeah that's my thinking too, and the major benefit of doing things DIY, you can make a circuit with high quality parts and it is still affordable, something equivalent would cost 4-5x as much commercially. Could I have cut corners and made it cheaper? Sure, I could have used Hammond chokes in the power supply with higher ripple, cheapo output transformers, a lower gain / less linear input tube at the cost of power output and maybe then I could have gone for cheaper anode chokes. Maybe even a lower quality off-the-shelf chassis by giving up my ability to design and customize it, putting a higher burden of the prep work on the builder. I could have avoided the steel Lundahl transformer shields at the cost of aesthetic appeal and perhaps higher magnetic coupling between mains and output transformers. I think using the better parts is worth the cost and in some areas makes the assembly more simple, that is my style, and it shows in the end result in my opinion. Also, being able to order all of the iron from one place is a benefit, sourcing inductors from multiple places could cut costs but the benefit would be partially lost in the extra shipping charges. Using transistors instead of chokes is another way to cut costs, but of course this has its own compromises - the power supply would need to fundamentally change, the propensity for part failure would go up, and building the circuit would be less friendly to new DIYers.
@zach915m has the amp right now, I know he has compared it to his 45 amp and the comparison is very favorable.
@Monsterzero will have it next. I need to come up with a name...
Yeah, output impedance switch. Low is 32-150ohms, high 150ohms and up.
