Alright, Lundahl distributor says we are a go for transformer availability, just a 4-5week lead time given they will mostly be made in Sweden.
Here is what I've done with this output stage in this amplifier.
Below is a conventional cathode biased SET output stage (series feed), this is what you will find in a vast majority of transformer coupled single-ended tube amplifiers. The signal path for the output stage is comprised of the final components of the B+ supply, the output transformer, the tube, and the cathode bypass capacitor. The transformer is always in the plate of the tube.
So what would happen if instead we put the transformer in the cathode? It would look something like this.
The output stage signal path now consists of the B+ supply, the tube, and the output transformer. There is no need for a bypass capacitor!!!
This is the major difference between this amplifier and other transformer coupled amps - the output stage is a transformer coupled cathode follower. Similar to the conventional SET output stage, it is cathode biased, but rather than using a cathode resistor, we use the DC resistance of the output transformer primary winding to bias the tube along with some series resistance if need be.
So why go to the trouble? This output topology has a number or pros over the conventional SET approach, as well as some cons.
Pros:
1) A very clean signal path in the output stage - removing a reactive component from the output stage, the bypass capacitor, has huge gains in terms of clarity, staging, dynamics, realism. This same benefit is gained when using fixed / grid bias output stages, however they require a dedicated negative bias supply, much more complexity! This output stage keeps the tube cathode biased without requiring a bias supply - essentially you gain the benefit of a fixed bias design without the cost / size / headache of a grid bias supply.
2) Low distortion - a cathode follower inherently is low distortion due to its internal negative feedback. This amplifier has inaudible levels of distortion at normal listening volumes and it remains low all the way up to clipping.
3) Low output impedance and improved damping ratio - a typical SET amplifier will achieve roughly a 3:1 damping ratio. Higher damping ratios can be accomplished using a higher turns output transformer, however this is at the cost of copper losses, a less ideal output transformer, and power output. Using a cathode follower, and the specific tubes used in this circuit, damping ratios of 7:1 or 8:1 can be achieved, much better for driving low impedance and hard to drive planar magnetics.
Cons:
1) No voltage gain in the output stage - a cathode follower has a voltage gain of less than 1, meaning all of the voltage gain for the amplifier must be done by the input stage! This means you need a high gain input stage that can swing big time voltages at low distortion. Add using new production tubes into the mix and this was the hardest part of the design! I'll discuss the input stage later...
2) Dedicated heater windings - because the entire output voltage appears on the output tube's cathode, at peak swing you risk violating the tube's maximum heater-to-cathode voltage. If that happens, the tube could arc and it is toast! To avoid this potential issue, each output tube MUST have its own dedicated heater winding with the heater referenced to the tube's cathode. That means a mains transformer with at least three separate heater windings, plus a rectifier filament winding, which is not all that common.
So at a high level, this is the design of the output stage. I was able to come up with something that works within these constraints using common tubes that sounds really excellent (in my opinion). I'm certainly not the first person to try this, you might see bits and pieces about it on the web. It has been discussed to a small degree on diyAudio, but in the context of speaker amplifiers where the voltage swinging requirements of the input stage become ridiculous to the point of being impractical. But for headphones, it works quite nicely I've found
