Tjj226 Angel
- Oct 20, 2012
Will be interesting to see how that works out, I have seen other Audio Note AN-J and AN-E mimics out there, the Audio Note markup is serious. They are beautiful speakers though, love those blue hemp woofers.
I'll look into the cap replacements, need to ask the original owner if anything was done with the crossovers when the surrounds were replaced. I recall reading somewhere that you should avoid messing with them unless absolutely necessary as components were very specifically chosen by Snell, could just be one of those weird purist audiophile legends though. Will probably kick that can down the road, but I'll look into it.
The DAC in question is made by SW1X, a new kid on the block and also of the Audio Note school. The DAC End looks interesting, I have a small deposit down on the SW1X DAC, had planned for something in his middle performance tier, but if I backed off and put my deposit toward his most entry-level model, I could probably also build the DAC End for the difference in cost...
Something to consider, I do love a good DIY.
That is true up to a point. I went through the same anguish over swapping out the caps. What I did was I measured the capacitance with my meter and then bought the exact value parts. It worked great. Imaging was improved greatly.
