Tjj226 Angel
- Oct 20, 2012
@Xcalibur255
No, cleaning up your PC power is not the same as a USB decrapifier.
When you use so called synchronous USB your internal dac clock is slave to your PC. That means your Dac's jitter performance is almost entirely dependent on what is happening with your computer.
Unfortunately no matter what you do, your PC will always be a noisy environment and your clock/jitter performance will suffer. You can improve it with better power supplies and so on, but all you are doing is putting lip stick on a pig.
So long as you are not listening to DSD or some very high sample rate music, I would encourage you to look at using optical spdif with a better than walmart brand quality cable. Preferably a true glass cable. But if you have a M-ITX computer, I am going to take a wild guess and say you are probably limited to USB.
In which case, I would encourage you to look for some type of USB decrapifier that coverts your Synchronous USB to Asynchronous USB. Fair warning, they are very expensive and hard to find. I haven't found one that I would recommend, but I haven't looked that hard either.
With Asynchronous usb, you are just sending bits to your dac. The clock signal is actually discarded and the clock in your dac (or an external after market master clock) can take over.
Even if you want to cheap out and find a USB decrapifier that uses some decent galvantic isolation, you would still be better off.
