Xcalibur255
- Feb 4, 2008
I've looked for a Topaz a couple of times, but as you said they're already hard to find and usually salvage pieces that are all beat up. I know it's also somewhat common for them to hum and that would drive me crazy since it would be right next to where I sit. I had to return two TrippLites because they hummed as well, noises like that drive me crazy.I think we've talked about it before, the isolation transformer solution is a good one, but the transformers that are worth buying can be expensive and seem to be getting harder to find (Topaz, MGE, etc.), imperative that they be of low interwinding capacitance, otherwise the benefits aren't realized. So many companies are completely vague about what is going on inside their power conditioners, I tend to get serious snake oil vibes...
I view this subject the same way I view premium cables: it's almost impossible to truly make informed choices through research alone. So I just stay away from it. But when something remains "not quite right" for a long time as a setup goes through it's evolutionary path it's logical to look at the things one has never addressed or changed as the most likely sources.
I thought about trying a TrippLite medical isolator but widespread reports of hum shut that down too.
