Just to see what all of the hype is about, this morning I did another experiment.
You might recall that I left the driver tube cathodes unbypassed in the 6A5 amp given the CCS load. I had some leftover electrolytics from the build, some non-polar Audio Note Kaisei, I thought I would clip in the caps, bypass the cathodes, and see how it affected the sound. Many tube DIYers go to great lengths to remove these electrolytics from the signal path, but how bad can it be really?
The alligator clips I'm using don't have teeth, so the caps can be very quickly removed for listening comparisons.
The difference is pretty BIG! With the cathodes bypassed, there is a collpase in the soundstage, instrument separation suffers, there is less definition in the bass, and the high end sounds more harsh. It isn't subtle whatsoever. The amp doesn't sound bad with the cathodes bypassed, but once you've heard them unbypassed, no way you could go back. Audio quality is all relative after all. I did do some FFT measurements, bypassing the cathode resistors doesn't seem to affect distortion in a measurable way.
So the hype is real, keeping electrolytics out of the signal path is the way to go. Luckily in the 45 parafeed amp, I will be leaving the 6J5 cathode resistors unbypassed, and I should be able to get away with leaving the 45 cathode resistors unbypassed as well using the "Western Electric" parafeed wiring configuration.
This setup could potentially inject some power supply noise onto the cathode, but seeing as I am back to using a MOSFET cascode CCS on the output tube (rather than the pentode CCS), I think I will get away with it. That would leave only two capacitors in the signal path, the interstage coupling caps and the parafeed caps, which will both be high quality film types.
Since I am waiting around for parts again, the gears have started turning on an all DHT two-stage amplifier. This is probably a 2021 project, so I won't talk about the details. Might be collecting some tubes for it, but I'll certainly be looking into ways to avoid bypass caps in this setup too. To be continued...
Another thing I did yesterday, which you might be able to see in my photo above, was rerouting the B+ wiring from the mains transformer to the rectifier. A made a novice mistake routing this wiring along the periphery of the chassis originally. Keeping this loop area small should help with power supply noise, and seems to have made a measurable difference. Hindsight is 20/20.
TTFN!
TTFN!
