Ha! Understood, no worries. Yet to be determined on oscillation issues as I have only put together the PCB this morning, but have had no issues feeding cascode CCS in several designs with the reg. Time will tell! Possible it will take a few iterations, might have to add some HF decoupling if oscillation is an issue, fingers crossed.
The gyrator is inspired by Ale Moglia's design, here is a "Revamped DarkVoice" schematic with the gyrator in place. Reference voltage is generated by cascode LND150 CCS across 220K resistor to ground. Have taken the output from the plate, but could take the mu output as well, depending on how the original owner feels about transistors being in the signal path
