rettib2001
- Apr 29, 2013
I recently upgraded my system and added a Marantz 2 channel amp, mm7025, , the LKS having its own volume control sounds WAAYY better when I run XLR's straight to the amp, bypassing my DENON x4200 altogether and having my 2 subwoofers plugged into the unbalanced outputs of the DAC. The sound coming out of my B&W 705 S2'S is amazing. Does anyone else here use the LKS as a pre amp?, if so what crossover do you recommend so I dont run my speakers full range? Thank you
I'm using it as a pre-amp having concluded that it sounds better than going through my 'pretty good' passive preamp.
I am still however eager to hear if anybody has found a preamp solution that sounds better than the lks acting as adigital volume control as I can't shake the largely accepted theory that any digital control of volume effects the sound quality.
